Previous in Forum: SCR Electrical Power Controller   Next in Forum: Bonding of Earthing Conductor to Rebar
16 comments
Land Requirement for 230 kV SS
05/26/2014 12:31 PM
what will be the minimum land area required to construct a 230 KV substation?
Pathfinder Tags: 230 kv
Re: land requirement for 230 kv ss
05/26/2014 12:33 PM
If you put it on a roof of a large building or on poles high above a parking lot zero ground will be used.
05/26/2014 12:36 PM
5 acres, minimum.
05/26/2014 12:55 PM
The answer may be determined by surveying a number of existing 230kV substations. This can be done either in person, by using detailed maps or, at a push, by using Google Earth (usual disclaimer). No-one here has time to do it, sadly.
05/26/2014 12:56 PM
I wonder if ANSI has an answer for this....
Good Answers: 114
05/26/2014 3:54 PM
Naughty!
Good Answers: 114
05/26/2014 3:56 PM
230 KV incoming, how may outgoing circuits and what voltages?
05/26/2014 4:02 PM
What's the capacity and application? It depends on so many things......
Absolute minimum is probably 2-3 40 foot shipping containers, but that's just based on my experience with mobile substation designs.
05/26/2014 5:17 PM
A Van de Graaf unit could probably fit into a phone booth.
Good Answers: 444
Re: Land Requirement for 230 kV SS
05/26/2014 9:11 PM
Zero. Put it underground using a GIS system. Next time give more information and the answers you get may be a bit more informative.
05/26/2014 9:20 PM
I read somewhere on the internet that 5 acres was enough.
05/26/2014 9:28 PM
... and where do you put the transformer? . . .
Good Answers: 444
05/26/2014 9:33 PM
Anaheim, CA Park Substation, 110'x130' excavation, just about 1/3 Acre.
05/26/2014 10:38 PM
Depends on number of transformers,their capacity(MVA),secondary voltages,number of outgoing feeders,type of CB(vacuum,SF6 etc),design,specifications etc
pnaban
05/27/2014 12:24 AM
A further comment, you set up an account 2 years ago and this appears to be your first visit let alone first question. What gives? (as they say).
Good Answers: 70
05/27/2014 12:24 AM
Hopefully the OP has a bunch of land they want to lease to a power company for a sub station, otherwise I think they got a lot of home work to do.
Location: KCM, chingola; copperbelt; zambia; southern africa.
05/28/2014 3:19 AM
it like saying how much land do you need to build a four bedroom house. it depends on your design, some equipment needs much space others not.
an error does'nt become a mistake if corrected!
Register to Reply 16 comments
dj95401 (1); DmanEng (1); IdeaSmith (1); jack of all trades (2); lyn (2); passingtongreen (2); pnaban (1); PWSlack (1); RAMConsult (2); tcmtech (1); Tornado (2)
