We build hydraulic pumping units, and we have the reservoir built by a welding subcontractor. These reservoirs are frequently not square and true due to distortions introduced in fabrication during shearing, measuring, and welding processes.
I am told that the requirements for consistently greater accuracy in the squareness of these reservoirs is a signficant investment in such things as specialized equipment for welding and shearing.
I am interested in finding out if there are simpler ways to solve these issues.
The tanks are all build of 1/4" or 3/8" 44W steel (mild). The main issue is a warping of the the reservoir such that it will rock easily when placed on a flat surface, and when mating to a frame, doesn't line up well.
I am also interested in finding simple tools for QA inspection to determine the amount of deviation. (prior to entry into the factory, where there is no flat location) The tank shown here is 20" x 41" x 96". It is a low pressure vessel, meaning less than 15psi, and is vented to atmosphere. Our tolerances are basically +/- 1/4" for squareness.
Thanks,
Chrisg288@hotmail.com
