Previous in Forum: Overhead Power Lines, Earth Conductor Injured Because of Lightning   Next in Forum: Cable Sizing for Motor Feeder
Test Procedure
06/02/2014 4:32 AM
Dear CR4-Mambers,
Can you describe or forward the TEST PROCEDURE/ANSI/IEEE Std# 495-1986 for Cable Earth fault indicator ( Sensor installed at Elastimold cable dead break ).
Thanks,
Re: Test Procedure
06/02/2014 5:49 AM
Yes, were a legitimate copy of the standard to hand. Fortunately, obtaining a copy is so easy. One simply telephones the agency that supplies them and quotes a credit or debit card number, and the standard will arrive either electronically or through the post, whichever is preferred.
Re: Test Procedure
06/02/2014 8:58 AM
Just buy your own copy. Better yet, join the IEEE and use your membership services to view this document.
Re: Test Procedure
06/02/2014 4:18 PM
This standard is actually available for free off the internet, however that is likely because it is obsolete.
You should purchase IEEE 495-2007 from one of the standards websites instead.
Register to Reply 3 comments
jack of all trades (1); PWSlack (1); redfred (1)
