Previous in Forum: How to Become a Design Engineer   Next in Forum: Problem With Pneumatic Rotary Actuator
Industrial Engine Lube Pump
06/02/2014 12:51 PM
Hi
I am facing issues of overheating at compound gear bush area for engine type
K1800E which is basically goes in mining application which
Can any one help me with the Lube pump FTA so that I can anlyse and if any can provide me some product knowledge that would help me to investigate .
It has two pumpung gears and a compund gear connected to engine
Re: Industrial engine Lube pump
06/02/2014 2:03 PM
Have you tried the manufacturer's web site for help?
Have you called their tech people?
Who makes the engine?
Do you have an operator's manual?
Do you have anything?
Re: Industrial Engine Lube Pump
06/02/2014 6:35 PM
You should be running Synthetic Oil , which will not overheat .
Amsoil makes a hydraulic fluid which is fireproof .
Steele m a
06/02/2014 8:46 PM
And you base this uninformed statement on what?
The type of oil used will NOT prevent overheating. The oil may not burn like petroleum oil.
Stick to writing fantasy.
As Hobson said in "Arthur" Try not to speak!
06/02/2014 9:26 PM
06/03/2014 3:50 AM
Yes. Anybody who answers the telephone at Cummins can help. Make the call.
Good Answers: 48
06/03/2014 4:40 PM
You could also try talking to any of the major lube oil pump manufacturers. They are easy to find, and they generally know quite a bit about lube oil pump applications.
Register to Reply 6 comments
Holzfeller (1); lyn (3); PWSlack (1); steele_m_a (1)
