Previous in Forum: Acrylic Nail Softener   Next in Forum: High Speed Diesel
Treatment of Pulleys
06/27/2007 2:45 AM
Good Morning for all ,
I'm a Chemist and responsible for engineering specification for raw material and components and plastics in the biggest company in Egypt, i have a question about treatment of pulleys. What is the best way to treated against corrosion and tearing its belt?
i will great appreciation . Mohamed Mahmoud
Re: traetment of the pulleys
06/27/2007 3:34 AM
Please describe the materials of construction of the pulleys and belts, and the nature of the atmospheres they are subjected to.
06/28/2007 1:13 AM
the material is cast iron or GG alloy steel and atmosphree is condenser room at high max. temp is 52° c.
Safety - ESD - RF Manufacturing ESD Installer
Re: Treatment of Pulleys
06/28/2007 7:09 AM
Not being aware of the belt design I would recommend a light coating of of a petroleum base lubricant to physically treat the exterior of the pulleys. This is simply to deter corrosion. Paint, while longer lasting, therefore requiring less upkeep, can hide corrosion from inspection creating a hazard.
“The problems we face cannot be solved with the same level of thinking we had when they were created” Albert Einstein
Good Answers: 40
06/28/2007 11:03 AM
This is the 3rd corrosion topic that I have addressed here.... (a little "twist", on this version of my response, if I may) ~ Knowing what questions to ask is a sign of a keen mind. Knowing HOW to ask the question (including correct specifics/parameters) denotes a hint of knowledge in that mind. Knowing WHO to pose the question TO reveals Profound Brilliance(!) in that mind... If you deal with corrosion issues, go to the National Association of Corrosion Engineers International www.nace.org
Subscribe, there (for FREE) to the Network of professionals around the world (the NACE Corrosion Network / List Server), and pose your question to the real experts who make this their life's work. They offer classes and certification in numerous aspects of corrosion and the protection against same. You'll learn more from these forums than you ever DREAMED existed about the topic... Best regards, T.M.D.
Good Answers: 38
06/28/2007 11:47 AM
Are these drive pulleys and belts used for power transmission or are they pulleys to move belts that transport the raw materials. Consider using lagged pulleys for drives and takeups with a good epoxy paint to protect the sides and taperlocks used for transport. Oil on power transmission belts is usually not preferred due to increased slippage. Many pulleys can be purchased with protective coverings. Greasing all main bearings regularly will help protect them and keep out corrosives. sealed bearings are even better as long as cleaning the exteriors is also performed. For transmission pulleys you can paint the areas not in contact with the drive belts.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Anonymous Poster (2); charsley99 (1); jowens (1); ndt-tom (1)
