Previous in Forum: Kerosene and ATF   Next in Forum: Treatment of Pulleys
9 comments
Acrylic Nail Softener
06/26/2007 1:08 PM
Any suggestion on a solvent that can soften acrylic nail extension, attached by 'super glue' so that it can removed easier - at the same time not toxic to the human hand ?? i will greatly appreciate any advise .
Re: Acrylic Nail Softener
06/26/2007 3:44 PM
I don't know the toxicity, but...
http://www.theglueguy.com/products.htm#sol
Canada - Member - New Member
Location: Richmond Hill, Ontario (North Greater Toronto Area), Canada
06/27/2007 12:36 AM
The label on most any bottle of cyanoacrylate ("super glue") will tell you - acetone. Or soak for a VERY long time in soap and water.
You can have it good, fast or cheap. Pick two.
Good Answers: 42
06/27/2007 2:42 AM
I have had success with acetone breaking the super glue bond.
I don't know how the acrylic nail will behave.
Soaking in acetone is rough on the skin, so unless you are a guy that has to get rid of the evidence of an experiment before you are embarrassed, I wouldn't suggest it.
Any lady will tell you that nail polish remover has to be used discretely.
06/27/2007 3:37 AM
Acetone is the greatest proportion component of commercial nail varnish remover. It will soften the acrylic to the point where both it and the adhesive can be removed by mild abrasion with carborundum.
06/27/2007 9:15 AM
Hi PWSlack,
Many thanks for your response .Basically once acrylic hardens , I believe it is resistance to most chemical ... well I may be wrong and need advise . Acetone - the commercially high strength ones available ones are being evaluated is an option to soften acrylic nails . Acetone is often not used as it dehydrates the skin too much . I am looking for an alternative to blend it with acetone .
Good Answers: 42
06/27/2007 11:32 AM
Just an idea, how about blending it with glycerin?
Or mineral oil ?
06/27/2007 7:38 PM
Warm water: acrylic absorbs about 12 wt percent of water and swells. The nail will also absorb water, swell and soften. BTW acetone is used in most of the nail shops.
07/01/2007 3:52 PM
As you have been told, warm soapy water works best, either use large rubber gloves to hold the solution or sit in a bath with the hands under water.....but it will probably take a time to work, about the time that your soles will be seen to have that funny ridging after being in water a long time! But who cares?
07/02/2007 12:30 PM
Thanks for all the response ... water soak is safe .... but I can't ask my wife to soak her nails is a tub of water for a few hours !!!! The nail shop uses a acetone mixture ethyl that is not so carcinogic. an alternative is tough . Guess I have to live with what is being used at the moment .
Thanks
Register to Reply 9 comments
Andy Germany (1); Anonymous Poster (1); bhankiii (1); GW (2); Munky (1); PWSlack (1); sigmatron (2)
