Previous in Forum: Running an Engine Continuously at Low RPM.   Next in Forum: Lube Oil Discoloration Due to Intrusion of Water
30 comments
LPG Tank - Shell Thickness Calculation
06/07/2014 5:52 PM
Hi all,
I need to calculate the shell thickness of the LPG tank and I will appreciate if somebody can spare some time to give me an answer. I'm not sure about the pressure I should use for the calculation of the stress in the shell.
The tank is designed for max pressure 18 barg and the max temperature 45°C.
Propylene (among the gases that are intended as cargo) has the biggest pressure so I use it for the calculation. On 43.8°C it has 18 bar vapor pressure. The dynamic and static pressure in total is 0,72 bar.
Total pressure that is acting from the internal side will be 18+0.72=18.72 bar
From the outside we have 1 bar of atmospheric pressure.
Pressure used for the shell stress calculation will be 18.72-1=17.72 bar
Can somebody confirm that this calculation is correct? If not what do I miss? The problem is that my colleague say that I should use 18.72 bar for the shell stress calculation but I don't see any logic in that. Because if for example this tank would be placed in an environment with 3 bar external pressure the pressure for the shell stress calculation would be 18,72-3=15,72 bar?
Thank you in advance for any help you can provide.
Pathfinder Tags: LPG tank thickness
Re: LPG tank - shell thickness calculation
06/07/2014 6:02 PM
Follow the standards for where this tank will be used. Unless you follow the standards for where this tank will be used, you assume all liability.
Oh and don't forget a certified pressure release safety valve that will open at a pressure less than the anticipated burst pressure of your vessel.
Good Answers: 137
06/08/2014 8:52 AM
Pressure relief valve must be set at not more than vessel design pressure (not burst pressure) and max 10% overpressure allowed (at max relieving flow). Possibly PRV set pressure can be maximum allowable working pressure (MAWP) which could be higher than design pressure, but unlikely anybody will bother to calculate MAWP.
06/07/2014 6:21 PM
Seek the help of a local, certified mechanical engineer.
Someone will have to take ultimate responsibility for the design calculations.
An anonymous forum is not the place for certified calculations.
This is what could happen if the calculations are wrong:
Train car explosion bleve - YouTube
06/07/2014 6:25 PM
Unless the local code is crazy, you are correct, and your colleague is incorrect.
06/07/2014 6:29 PM
No safety factor?
06/07/2014 6:39 PM
The safety factor will be used later, using the formula for hoop stress and is connected to the TS and YS of the selected material. But before this I have to know the correct pressure that is acting on the shell and that will be used in the later calculation.
All of you can freely write your opinion about my question, you will not be responsable for any explosion as explained earlier. Don't warry :)
06/07/2014 6:50 PM
Good for you.
Glad to hear that you are using the correct design process.
I really wasn't too worried, since I assumed that all the correct procedures would be followed.
It's just good to hear it from you.
Good Answers: 70
06/07/2014 10:00 PM
Seems our Chicken $hit rater is at work again, huh? You brought up a legitimate concern, so I took upon myself to offset the OT.
Dan
06/07/2014 10:10 PM
The OP's question wasn't about safety factor; it was about which pressure to use--absolute vs. differential or gauge. ASME uses the latter. Joint efficiency hasn't yet been asked about, either.
06/07/2014 6:31 PM
Thank you for your replys.
All the calculation will be at the end reviewed by the side of one of the classification societies. So there is not any danger that enything will be produced and delivered just like that :)
The calculation I have to do is because we need to see the approximate cost of the tank production after what the decision wheteher we will enter in this project or not will be taken.
The tank shall be used for marine purpose and built according ASME VIII D2 and IGC code.
06/07/2014 6:55 PM
If not already included, you may need also to account for the pressure from the height of the liquid.
06/08/2014 1:46 AM
Yes it is included. I wrote above that dynamic and static pressure is total 0,72 bar.
I wander why he insist that the 18,72 bar should be used?
Maybe he confused the tank filled with LPG with the tank filled with water? In case the water is in the tank then you have the dynamic+static pressure, vapor pressure on higher temperatures, atmospheric pressure inside the tank and atmospheric pressure outside the tank. In this case the 18,72 bar should be used for the shell stress calculation. But when the tank is filled with the LPG then is only LPG inside. As far as I know when you fill the LPG tank you have to first substitute the air with inert gas and then the inert gas with LPG.
Good Answers: 183
06/08/2014 6:07 AM
If your pressure are "absolute" you can make the difference if they are "relative" they are measures against atmosphere so that the "internal" pressure has to be considered since it is already by measure the difference between absolute internal pressure and ambient.
I have the feeling that "barg" means gauge value you should check if the gauge did the measure against vacuum or against ambient.
06/08/2014 5:19 PM
I think that I see where I'm wrong.
Propylene on 43.8°C is 18 bar, but bar absolute? I was using it as bar gauge.
Good Answers: 137
06/08/2014 10:12 AM
In UK LPG tanks are designed for 17.3 barg (= 250 psig). That's based on propane and max temperature 50°C which gives vapour pressure ~ 17 bara (16 barg). I don't know whether that's because nobody has noticed that vapour pressures are in bara but vessel design uses barg (on the reasonable assumption that usually there is atmospheric pressure externally), or whether the 1 bar is kept in for safety, but it works OK in practice.
Propylene has somewhat higher vapour pressure than propane. Only data I have says 10.1 bara at 19.8°C, 20.3 bara at 49.5°C. But taking your 18 bar at 43.8°C, pressure is a bit higher at max design temperature 45°.
Also if you're going to take external pressure 3 bara into account, giving lower shell stress, this only applies if it is always under that pressure. If it can also be in ordinary atmosphere (or lower) stress is higher.
How do you calculate 0.72 bar static + dynamic? As the liquid SG is about 0.6 it would be quite a tall vessel to give anything like 0.72 bar static. Any dynamic losses do not raise the vapour pressure above that determined by the temperature. Dynamic loss results in lower pressure downstream of any pipework.
06/08/2014 5:04 PM
0.72 is static and dynamic calculated together. Only static is 0.2 if I remember well.
Good Answers: 137
06/09/2014 6:25 AM
OK, I may be missing something, but I don't see how dynamic loss can increase the pressure in the vessel above vapour pressure. If you give a bit more detail, it might be possible to get rid of the extra 0.52 bar for vessel design.
Not that 0.52 bar additional safety isn't a good thing!
06/09/2014 4:35 PM
The stress on the shell is caused not only from the vapor pressure but also from the fluid weight (static pressure) on the lower part of the tank and also from the dynamic pressure (cargo moving in the tank during the rough sea).
When the cargo moves the impact on the shell can be significant, so it has to be calculated for the worst case and added to the vapor pressure and static pressure.
Good Answers: 137
06/10/2014 6:13 AM
OK thanks I get it now. I had assumed your dynamic pressure was based on pipe losses.
Good Answers: 183
06/11/2014 9:50 AM
Because of the dynamic loads in case of sea transport I would considut NOT ONLY the pressure as a criterion but also the reservoir stability as a whole. Similar problems occur for instance in rocket reservoirs with a low pressure but a lot of dynamic loads.
06/11/2014 11:55 AM
POGO!! This is a very good point, glad you brought it up. While I don't think the POGO levels would ever reach the frequencies and levels of a "no go" situation for a rocket, I really have no idea. Not really a POGO effect either, but it's a close enough analogue. Dynamics involved in naval transport of cargo will depend on pretty much EVERYTHING you could think of, from ship size, speed, roll and yaw, position of cargo in or on the ship, tie down practices, those are just the obvious.
So do the maritime standards have a reference guide or guidelines for all this stuff so you can design the vessel to basic dynamic loads and target resonant frequencies to avoid? Or is all of this stuff built in to the standards for vessel support?
06/11/2014 12:11 PM
POGO? I miss Walt Kelley's work, but I see no relevance here. I do not think you are talking about the Project On Government Oversight. You might be playing a game with us.
If you're trying to explain something, undefined jargon is often a waste of time.
06/11/2014 4:16 PM
Previous post referenced that the effect would be like something that occurs in rockets that have a liquid reservoir. I just took it a bit farther by referencing the pogo effect that was seen early on in the Saturn V program. Shouldn't have capitalized the word as it is not an acronym. The term was coined in rocketry because the effect is very similar to that of a pogo stick. Basically the thrust caused compression in the rocket which caused fuel flow to change, thus changing the thrust, changing the compression, changing compression, on and on. Although it was supposedly taken into account, bad research/data gave a fake sense of the handling of the effect, and the rocket became a self exciting pogo stick with massive longitudinal vibrations. Basically, when all was said and done the complete system operated at a nasty resonant frequency. While there is no self excitation in this case, the end results can be the same. Liquid in the vessel can be sloshed about and if the frequency is correct it will create larger forces than expected. Definitely more prominent in vessels that are completely filled as pressure waves traverse back and forth through the liquid, and much more of a concern for spacecraft due to the small weight requirements, but it's still a concern that must be taken into account in any non stationary vessel. Just Google pogo rocket, it will lead you through a much better explanation, and should point to sloshing effects as well. Sorry for the confusion, but honestly, I thought this was a well known phenomenon and term in the engineering world(I know we spent about a week going over this in one of my capstone courses), and I did make the reference to pogo and rockets in my post, and said that while this really isn't what goes on in this case, the end effects are analogous. Steve
06/12/2014 6:28 PM
Of course that whenever you design something that will be used on ship you have to include a lot of coefficients concerning the max waves, area of use (no limit, inland water, etc), about ship dimensions etc... It is not just like that, you have a lot of calculation to do.
Re: LPG Tank - Shell Thickness Calculation
06/09/2014 12:22 AM
It's been quite awhile, so I'm not up on the codes, but I'd say that you can't go wrong designing based on the absolute pressure in the tank, and in fact I would think that you wouldn't want to. That's just me thinking logically, if the code says otherwise or I'm way off base let me know.
For simplicity let's assume you're designing to the yield stress. At sea level you would have a positive safety factor, and if you ever launched this thing into space the safety factor would go to zero. If you subtract a bar, your safety factor would be zero at sea level, and go negative with any increase in altitude ASL.
Totally agree with some others. If you design for a 3 bar environment, it always needs to be in that environment. A relief valve set to actuate at a gage pressure of 15 bar would be required for an event which cause the environment to change.
Anyway, I haven't performed design like this since college around ten years ago. So the assumptions are liberal and I just ran things through with some pretty simple logic (no sleep, trying not to think too hard lol). So real world conditions in the tank, safety factors, etc, really weren't given much thought. It's just basic thinking on my part as to why absolute should be used.
Like I said, If I'm out in right field or the code states differently, I'd appreciate it if someone more knowledgeable could correct me. And I know you would never design to yield stress :). Always looking to learn!
Steve
Good Answers: 137
06/09/2014 6:44 AM
Just a comment on safety factor - an appropriate design pressure is determined by everybody involved (including standards) and likely to have some safety. This is then used in vessel design, and the design stress allowed by the code (based on material selection, temperature etc) includes a safety factor on the yield stress and the UTS.
06/09/2014 2:27 AM
Hi, Lupezan: Please try specification, http://en.wikipedia.org/wiki/EN_13445.
06/09/2014 9:40 AM
The person who can confirm that the calculation is correct is the Engineer/Surveyor for the company covering the vessel for burst and collapse indemnity insurance. It starts with a simple telephone call to that individual. What happens next depends upon the outcome of the call.
Good Answers: 266
06/09/2014 11:22 AM
If these tanks are to be filled to 100% of their volume in liquid. Then the vapor pressure does not work. Stress do to thermal expansion of the fluid will exceed the stress of working pressure of the vapor. Most these tanks have working pressure of 240psi(16.54bar). Tested to 1.66666 of the working pressure. And have a relief valve not to exceed 5/4 the working pressure
Because of this problem a few years back they regulated tanks to 80% fill here.
Since you have not stated the application. That extra 20% may have some value you need to look at.
06/09/2014 4:44 PM
Yes, later I stated the application, it is for marine purposes. According the IGC code the tank can bi max 98% full in order to always have the vapor phase.
Register to Reply 30 comments
Codemaster (5); dj95401 (1); Iceberg86300 (3); lupezan (8); lyn (3); MalteseXXX (1); nick name (2); ozzb (1); PWSlack (1); redfred (2); Tornado (3)
