Previous in Forum: Flue Gas Temperature Fixing in Boiler   Next in Forum: Cantilever Threaded Connection
10 comments
Water Pump
06/09/2014 3:19 AM
why water pumps vibrates...?
not continoues vibration after short period of time, as a example after each second.
Good Answers: 109
Re: water pump
06/09/2014 3:53 AM
Is there maybe air in the lines?
Re: Water Pump
06/09/2014 9:22 AM
What size pump?
What is in the pump, its temperature and pressure?
How much suction head is there?
Is the pump trying to pump something it shouldn't, such as potatoes, a cable tie, a squirrel or a house-brick?
Re: Water Pump
06/09/2014 10:55 PM
May be foundation bolts are lose,alignment not good,no vibration isolators under baseframe or discharge line.
pnaban
Re: Water Pump
06/10/2014 6:42 AM
What is the application - fully described - Nihal?
My gut-feel is a damaged and, therefore unbalanced impeller.
Re: Water Pump
06/10/2014 8:54 AM
That might have been the house-brick....
Re: Water Pump
06/10/2014 8:57 AM
Is it still on the manufacturer's published performance curve against which it was specified, procured, installed and commissioned?
What is the maintenance regime on this pump? What spares are to hand?
Re: Water Pump
06/10/2014 9:03 AM
First of all, these folks are just chasing their tails without any real validity to their theroy's.
Do the following:
If you have a close coupled pump, check: Impeller & Mechanical seal
If you have a pump with a coupling, check the rubber material, If rigid & cracks replace it.
Every hydronic system will also include air vents at high points, so it's not air. Unless the air is being pulled from around a system component.
This is always a due process of illimination method, so get to it and report back.
If you do nothing, so is the reward - R. Hulette
Good Answers: 109
Re: Water Pump
06/11/2014 10:05 PM
You making it sound like its out fault that there was not more information provided in the OP. Me also thinks you are chasing YOUR tail big time.
The air vents you mention in the "hydronic" system would vent the air unless its pulling it in somewhere??? Which one is it? Can there be air in the system or not.
Is that your theory?
Welcome in the Guessing World of CR4.
Re: Water Pump
06/11/2014 9:26 AM
My small irrigation pump (Yamaha 5 hp model), also gives a real 'shake' as it gains suction. I have been putting it down to a normal torque reaction - going from an un-primed state to a primed one where the impeller is working, in the first instance, against air [no torque reaction] - and - , in the second instance, working against water [torque reaction].
It is the same effect as if one were to quickly release the clutch of your car.
Out in a Bowt
Good Answers: 21
Re: Water Pump
06/13/2014 7:26 AM
I'm going to try Sherlock Holmes method here by making some assumptions.
Assuming you have a centrifugal pump,
and it is working within the operating curve
and close to the best efficiency point
and the motor for the pump is the one which came from the supplier
and that motor is in good condition
and it is electric
and the pump has regular maintenance
and is in good condition
and you are not experiencing cavitation
and your pipe work is in good condition
and you are pumping a fluid suitable for that pump
and your pump is belt driven from the motor!
I would deduce that the vibration is from the motor belt. What else could it be. Problem solved, next question.
Well it works for Sherlock, maybe not in real life but it goes to show the variables which you must consider and why this question cannot be answered without more info. You could probably double or treble the number of assumptions I made here if you think about it.
Register to Reply 10 comments
IdeaSmith (2); MACA (1); MalteseXXX (1); pnaban (1); PWSlack (3); RandallAvery (1); snowboy (1)
