Previous in Forum: Current in 1.6 mm Kanthal DSD Wire in Coil Form   Next in Forum: Control Strategy Can Be Used Both For Grid Connected/Stand -Alone Mode of WECS
Lugs for Cables
06/10/2014 12:45 AM
Hi everybody,
I have a motor of 75 KW to be run along with the vaccum pump.
I have a cable of 150 Sq MM with M12 lug crimped on it. The motor terminal has bolt of M16. I want to know if there are lug adaptors or reducers which can be used with our M12 lug for testing this motor.
Re: Lugs for Cables
06/10/2014 1:23 AM
Personally for testing I would either drill the lug or make up short copper links with correct holes at each end. I would not leave the links as a permanent feature as they could swivel on the single fixing and cause a short circuit, as I would not think the motor terminals would be setup to prevent this happening
Good Answers: 42
Re: Lugs for Cables
06/10/2014 2:22 AM
There are 150 sqr.mm conductor M16 stud hole lugs.For instance:
LCMA150-16-X of Panduit .See:
http://www.panduit.com/heiler/ProductBulletins/D-PCCB13--WW-ENG-MetrcLugs-W.pdf
Celesta MC1816
http://wayspace.cn/Download/Metric%20Compression%20Lugs%20Catalog(6mm~240mm).pdf
and other[not Burndy !].
Julius
Re: Lugs for Cables
06/10/2014 3:05 AM
What thickness and length of copper strip do you recommend for 75KW motor
Re: Lugs for Cables
06/10/2014 3:34 AM
It would be the physical size of the lug you need to consider. I would think you would need something about 30 mm wide so 5mm thick would be fine for testing. You need something around the same size as your cable
Location: KCM, chingola; copperbelt; zambia; southern africa.
Re: Lugs for Cables
06/11/2014 3:35 AM
some questions, i just wonder where you pipo work
an error does'nt become a mistake if corrected!
3PhaseDesign-Craig (2); 7anoter4 (1); DmanEng (1); kesari (1)
