Previous in Forum: How to Read Graph for Circuit Breaker Testing   Next in Forum: Lugs for Cables
Current in 1.6 mm Kanthal DSD Wire in Coil Form
06/07/2014 9:04 PM
Can I pass 16 Amp current in 1.6 mm Kanthal wire in coil form to achieve 700'c max temperature in a furnace.
Re: Current in 1.6 mm Kanthal DSD wire in coil form
06/07/2014 9:25 PM
No.
Not without a lot more information.
Good Answers: 445
06/07/2014 10:15 PM
Maybe you can find your information at the manufacturer's website.
Re: Current in 1.6 mm Kanthal DSD Wire in Coil Form
06/09/2014 11:42 AM
Yes, as long as all safety protocols are followed. Beware that the melting point may be as low as 1200C, so thermostat must be close enough to prevent meltdown.
Good Answers: 42
06/09/2014 11:52 AM
If what you meant is "resistance coil in air" you could use this:
http://www.farnam-custom.com/library/engineer-talk/estimating-the-resistance-wire-temperature-for-an-open-coil-heating-element
Julius
Register to Reply 4 comments
7anoter4 (1); lyn (1); RAMConsult (1); StandardsGuy (1)
