Hi folks!
I need an AC/AC converter in a wide range. Let's say 660 AC to below to 305v AC. I am not willing to use any step-down transformer. Recently I found out that there is a structure that is called "Buck". When I simulate the circuit with the help of LS-SPICE, I get impure SIN wave at the out-put.
If the functionality of Buck is proven, why I get it wrong?! Did I bias the transistor in a wrong way maybe?
Any live example of Buck or other converter you may know please?
Thanks.
P.S. Here is an article with its example that I could not make it to work!
http://dspace.bracu.ac.bd/bitstream/handle/10361/1840/Design%20of%20a%20single%20phases%20AC-AC.pdf?sequence=1
