Previous in Forum: Maximum Voltage Drop in Cable Size for Transformer Feeder   Next in Forum: AC/AC converter --- Buck
Relay Coordination
06/20/2014 2:04 AM
I need to do relay co ordination
any one can guide me for relay co ordination, and any technical article can any body share
Pathfinder Tags: Relay co ordinator
India - Member - New Member
Good Answers: 164
Re: Relay co ordination
06/20/2014 5:25 AM
Assuming you are referring to Type II Coordination of Motor Starters, here is a good link:
WEG Type 2 Coordination of Circuit Breakers and Motor Starters
Good Answers: 266
06/20/2014 7:23 AM
06/20/2014 7:36 AM
British Standard 7671.
Good Answers: 131
06/20/2014 8:18 AM
Protective relay coordination is not a task for the untrained. There are many parameters and conditions that need to be taken into account to properly coordinate relays. If not done correctly, the result can be catastrophic failure of electrical equipment and injury (or even death) for operating personnel.
If you want to start to learn about relay coordination, GE has a great (free) download of their "The Art and Science of Protective Relaying" at the following link:
http://www.gedigitalenergy.com/multilin/notes/artsci/index.htm
Start studying it, and you will learn a lot. But in the meantime, hire someone who is trained and qualified to do your coordination study - it will be money well-spent to be assured that it is done properly and safely.
06/20/2014 8:53 AM
Thanks for sharing a valuable book
Good Answers: 244
Re: Relay Coordination
06/21/2014 11:32 PM
This is one of the best documents for the relay coordination:
http://epowerengineering.com/guides-part-5.pdf
- MS
Location: I live in USA, Colorado in the houses of 7 Summits
07/29/2014 4:13 AM
The term relay coordination covers various concepts as discrimination, selectivity and backup protection. Relay coordination is not combined only with relay or equipment's operating characteristics. It also includes some other protective device characteristics such as Fuse, MCB's, Circuit Breakers as applicable
Register to Reply 7 comments
DHARAMRAJSINH (1); kvsridhar (1); msamad (1); ozzb (1); PeterT (1); PWSlack (1); ShawnHoppe (1)
