Previous in Forum: Capacitor Testing   Next in Forum: Low Voltage Set Point
Neutral Grounding of Standby Generator
06/22/2014 12:15 AM
If station service transformer (SST-240/120v-y/y solidly grounded) from utility and standby generator are in same substation ground grid then is it required to ground neutral at 1st disconnect means panel of SST?As per NEC code it shall be but most of case when neutral coming from outside not in same grid. It's separately derived system with manual transfer switch. Comments and advise are appreciated.
Re: Neutral grounding of stand by generator
06/22/2014 12:29 AM
Comment: You shouldn't have to ask.
Advice: Get professional help.
Good Answers: 181
06/22/2014 7:26 AM
This is getting monotonous, you asked the same question yesterday.
Didn't you like the answers?
Good Answers: 44
Re: Neutral Grounding of Standby Generator
06/22/2014 10:07 PM
"Neutral coming from outside"
Here lies the crux of your question.
See response number one.
06/23/2014 12:18 AM
it is always wise to use four opole breakers, which circumvents earthing clash uissues. better keep earths isolated - to avoid fault imaging into another circuit.
Let us discuss the practical issues not the classroom.
Good Answers: 44
06/23/2014 12:53 AM
Yeah, what he said...fault imaging...a classic issue.
cuba_pete (2); lyn (1); M.R.Iyengar (1); TonyS (1)
