Previous in Forum: Neutral Grounding of Standby Generator   Next in Forum: Audio Capacitors
14 comments
Low Voltage Set Point
06/22/2014 11:38 AM
I recently purchased my 3rd refrigerator in the past 6 yrs. The first expired due to lightning strike, the 2nd the line power dropped below some level, didn't go off but caused my CFL's to flicker. The manufacturer states 115 VAC, my typical line voltage is 125 VAC. I have a delay on timer, but I'm looking for a low voltage drop out relay. My question is what would be a typical value for a set point?
I have a Variac and the appropriate meters, just need a value.
Re: Low voltage set point
06/22/2014 12:05 PM
~100v...
06/22/2014 12:58 PM
Once again I thank you
Good Answers: 50
Re: Low Voltage Set Point
06/22/2014 4:42 PM
2 failures in 6 years, I've seen where kitchen cabinets (too close on all sides and top) hold in the condenser heat, and cause early compressor failure. Do you have enough space above the refrigerator, to let all the heat out from the rear? Just want to state another possible failure issue that may not be obvious to cause issues.
I currently have a Whirlpool side by side that has doors that annoy me to want to crush it. They only swing open 120 degrees, and as it's a 33 inch wide, are always in the way. That and the glass shelves that are always covered in some film requiring cleaning. My previous, had wire shelves, it failed from a leak at a aluminum to steel tubing joint. Lasted 22 years.
ignator -
Good Answers: 102
06/22/2014 10:55 PM
I had, still have in the shed, the same fridge. I retired it, still working, after 19 years. It was really guzzling juice. I manged to keep it going with minor repairs..easy to fix.
I was able to open the doors out wide so didn't have access problems. I didn't notice any film build up on the glass shelves though. I like glass shelves as they contain leaks better than racks.
I have a Panasonic fridge now. Smaller, but enough. My power bill plummeted.
06/23/2014 7:15 AM
You know Wal, I'll have to agree with you there......I didn't believe it at first........but you are dead set right..........I tried liquid on the wire rack shelve and look what happened!!!
Sorry Wal...........but, I could not resist that one.
Good Answers: 102
06/23/2014 7:41 AM
You could go another year without cleaning that...
Good Answers: 27
06/23/2014 7:58 AM
Typical and acceptable voltage range variation allowable is +/- 10%. Equipment manufacturers are also aware of this as well... and therefore designed and normally tested their product to function marginally for a short period of time up to as low as 95 volts. So the 100 volts mentioned earlier is a good safety limit..
vsar
06/23/2014 11:28 AM
They just don't build them like they used to. My wife and I used the original refrigerator my parents bought in the late 1940's, into the late 1970's. Let it go when the apartment we moved into came equipped with a nice shiny newer and larger unit. We gave it back to my parents as a beer fridge and it ran for another 15 years after that. It saw plenty of power outages and power dips in rural Pa. My parents lived in an area so rural they had lines down from ice in their neck of the woods one winter, and didn't get power back for 12 days. Power company had to take care of the bigger towns first.
06/23/2014 9:35 PM
But the new ones all have an "Energy Star" rating!!! I think the old "Mobil Economy Run" of days gone by, offered a more honest approach.
06/23/2014 12:12 PM
Low voltage, under 100 volts where you are and under 200 volts where I am, causes single phase motors often to overheat.
A badly installed fridge, as someone mentioned already, would be even more susceptible to failures through over heating.....a fridge MUST have cooling air passing over the rear coils to remove heat (as well as for the compressor motor!).
The fridge efficiency, even if the over heating doesn't actually cause the fridge to fail, will still be far worse than they should be. E.G. More electricity is being used, temperature maybe not as cold as it should be, food freezing may take longer etc etc etc...it could even become a health problem in some cases....
Just a thought or two!!
06/23/2014 1:03 PM
Lets not forget to clean those coils regularly. We've overheated our fridge by forgetting to move it away from the wall and get a vacuum cleaner after it every couple of months.
06/23/2014 4:40 PM
If correctly ventilated, they do get REALLY dirty.....you make a very good point!!!
Good Answers: 102
06/24/2014 1:37 AM
Most if not all new domestic refrigerators have there condensors under the skin of the cabinet on one side. No external condensors to get covered in fluff, hair and what not. Can push it right up against the wall but the sides and top need air circulation.
06/24/2014 2:01 AM
Let's ask: Do you have a power quality problem or do you want to just throw money at it?
Are we talking about a simple refrigerator where all you have is a defrost timer, motor and thermostat or some expensive microcontroller thingy or even an ifridge or something?
If lightning is an issue, there are ways of dealing with that. If surges are the problem, there are ways of dealing with that. RFI? brownouts? For those critical things, there is always a UPS.
If lightning really is an issue, then consider lightning rods.
Probably the best thing you can do is do an electrical inspection. A whole house surge suppressor is also worthwhile. That at least has a chance against lightning.
If you want to find out what you need, rent a power line disturbance monitor for a week.
Register to Reply 14 comments
Andy Germany (2); ignator (1); JWthetech (2); KeepItSimpleStupid (1); MOBI (1); Phys (2); SolarEagle (1); vsar (1); Wal (3)
