Previous in Forum: Analog Varh Meter   Next in Forum: Digsilent Powerfactory - Load Profile Import
Welding Machine
06/23/2014 4:32 AM
Dears:
why 2 ph. welding machine when work let the 3 ph. analoge watt hour meter return .
or stop if it has a brake .
thanks
sokrer
Pathfinder Tags: welding machine behavior
Re: welding machine
06/23/2014 7:59 AM
Come again please. What has a brake? Is the meter turning while the welder has a break?
Re: welding machine
06/28/2014 4:38 AM
Dear :
I mean when I use 2 phase welding machine then the three phase wattmwter goes reverse ( the disk is run back ) .
= the brake is on the rotating disck to prevent it from going reverse.some of new meters include this.
sokrer
Re: Welding Machine
06/23/2014 3:53 PM
Did you think you had found a loophole and that because you were drawing off all three phases, that the power meter wouldn't register your use?
Even if you only draw power from a single phase, you should expect a bill from the power company.
Re: Welding Machine
06/28/2014 4:44 AM
Dear:
I mean in case of electromagnetic waat meter the disk rotating and meter regestration goes back when I use 2 phase ( 2 gines) welding machine.
Power consumption is being reverse
sokrer
Re: Welding Machine
06/28/2014 6:28 AM
Power consumption is definitely not being reversed using a welding machine.
If your meter is running backwards, the power company will probably notice after not too long. Power companies are not too keen on people using power that they do not pay for.
Re: Welding Machine
06/24/2014 7:08 AM
Welding machines are usually classified as constant current (CC) or constant voltage (CV); a constant current machine varies its output voltage to maintain a steady current while a constant voltage machine will fluctuate its output current to maintain a set voltage. Shielded metal arc welding will use a constant current source and gas metal arc welding and flux-cored arc welding typically use constant voltage sources but constant current is also possible with a voltage sensing wire feeder.
The nature of the CV machine is required by aluminuim gravity die casting and flux-cored arc welding because the welder is not able to control the arc length manually. If a welder attempted to use a CV machine to weld with shielded metal arc welding the small fluctuations in the arc distance would cause wide fluctuations in the machine's output. With a CC machine the welder can count on a fixed number of amps reaching the material to be welded regardless of the arc distance but too much distance will cause poor welding.
Re: Welding Machine
06/28/2014 4:49 AM
Dear :
whate is the two phase welding machine influance on the watt meter ?????
why the consumption of watt hour be back while it is working ???????
Thanks
sokrer
Register to Reply 7 comments
IdeaSmith (1); joshuaseigel (1); sokrer (3); truth is not a compromise (2)
