Previous in Forum: Welding Machine   Next in Forum: Active Power Measurement at Very Low pf (0.003)
Digsilent Powerfactory - Load Profile Import
06/23/2014 5:06 AM
Hi, I am new to PowerFactory and had a doubt. I am doing a load flow analysis of a 1- phase system. For the load profile, I want to import data for a day from a csv/txt file but I can't find a method to do. Could anyone guide me regarding the steps?I tried searching online but could not find any help.
Pathfinder Tags: PowerFactory
Good Answers: 50
Re: Digsilent Powerfactory - Load profile import
06/23/2014 6:02 AM
You need to use a spread sheet application like MS OFFICE Excell, or Open Office spreadsheet.
So assuming you have a csv file saved on your drive, open the spreadsheet application and import the file. If it is a csv (comma separated values) then a pop up menu will ask you to indicate any formatting separation syntax, in this case select 'comma'.
ignator -
06/23/2014 6:13 AM
I have a csv file with the loads defined. I tried to import it using the parameter characterstic from file feature in Powerfactor. That was successful. But when I do the load flow analysis, it takes only the first value in the csv file and doesn't go to the next value after 1 second. The csv file is of the format
#timestampconstant_power_A
8/31/2011 23:594.557533
09-01-2011 00:004.55245
09-01-2011 00:014.549183
09-01-2011 00:022.8163
09-01-2011 00:031.471467
09-01-2011 00:040.713717
09-01-2011 00:050.6915
I also tried editing it using min instead of timestamp:
minconstant_power_A
13.028083
20.918817
30.542183
40.285
50.285933
06/23/2014 7:53 AM
Looks like your format in the first timestamp cell is different than the other cells. This would be a starting point to format all as date/time and try again!
06/23/2014 6:19 AM
Also I tried importing the data as a .dat file directly on PowerFactory, then it gave me an error that the file cannot be read!
Re: Digsilent Powerfactory - Load Profile Import
06/24/2014 4:42 AM
It still gives me an error "File has less number of samples than the scale object requires". what does it mean?
IdeaSmith (1); ignator (1); shivam1989 (3)
