Previous in Forum: Frozen Electric Door Lock   Next in Forum: Quartzite in Hot Mix Spec for Ontario Roads
Dreamliner Pretends to be F15
07/14/2014 8:20 PM
User-tagged by 1 user
Re: Dreamliner Pretends to be F15
07/14/2014 10:40 PM
The attitude after that takeoff was so steep and the image was so clear, I thought that this was a CGI animation at first. An impressive plane.
07/15/2014 12:23 AM
That's called a short field take off. Or, maybe just a "pilot show off".
The trick is to leave the runway and then just skim along the ground gaining air speed. Then, when you run out of runway pull back "smartly" on the stick/yoke. Trade air speed for altitude until you run out of airspeed, then level off.
Yes, very impressive!
07/14/2014 11:42 PM
Lotsa fun for that pilot! Years ago, I also heard of a 747 taking off on only one out of four turbines, though lightly loaded. Boeing has done some impressive stuff.
07/14/2014 11:53 PM
Awesome....
Good Answers: 61
07/23/2014 10:29 AM
The AVRO Vulcan used to do the same stunt way back in the 1960's at air shows on just 80,000 lbs. total thrust and gave the impression of a vertical climb from behind. As others say - very lightly loaded, carrying just enough fuel and trade speed for climb. Always impressive with a large aircraft.
energyconversion (1); lyn (1); redfred (1); SolarEagle (1); Tornado (1)
