Previous in Forum: Potmeter p,r,v are Given, to Find I   Next in Forum: Generator Safety
Problem Faced in Conzerve EM 6400 Meters
07/19/2014 2:33 AM
HI I am facing probelm in 11 KV HT switchboard:
I hvae one i/c feeder & 3 distribution trafo o/g feeders.
Each feeder is having conzerve meter EM 6400 meter of same accuracy class. We are facing difficulty that
KWH of i/c is not equal to (sum of kwh for distr trafo1+sum of kwh for distr trafo2+sum of kwh for distr trafo3) when plant is on full load capacity.
We are getting correct KWH values from meters as we have checked CT connection of all feeders.
Pls suggest.
Re: Problem Faced in Conzerve EM 6400 Meters
07/19/2014 10:37 PM
07/20/2014 6:15 PM
I your totalizing meter is on the primary side of the transformers and the sub meter is on the secondary of the 3 transformers, you will have a difference in the readings.
07/21/2014 12:47 AM
All meters are on 11 kV voltage level.
Register to Reply 3 comments
jagdish agarwal (1); lyn (1); wareagle (1)
