Previous in Forum: Low Current, High ACB Rating   Next in Forum: Power Distribution
Earthing Of Pump And Vessel
08/04/2014 12:43 AM
We have 2*75KW motor coupled with pump... I had earthed motor on two sides.. Do I have to earth pump and I have a small vessel do its required to earth pump and vessel....?? Plz anyone clarify me..!!
Re: Earthing of pump and vessel
08/04/2014 8:09 AM
Follow the electrical code that applies to the country of the installation, which is not specified in the original post; in the UK, for example, it is BS7671.
Re: Earthing Of Pump And Vessel
08/04/2014 10:05 AM
I'd be curious to know materials of construction for all wetted materials.
08/04/2014 11:36 PM
Do the pump and motor have electrical continuity with metal baseframe and pressure vessel?.
pnaban
08/05/2014 1:30 AM
I assume it is water pump.Is it skid mounted?
The pump and the motor must be mechanically connected to each other,plus because of leakages there is a chance of electrical leakage.Earthing the pump will be more prudent and will cost less than the time on the discussion.
08/05/2014 4:03 AM
No the motor-pump base is a civil one not mounted in frame.. the pump output have been connected to the vessel and its not pressure vessel..!!
08/28/2014 11:05 AM
Metal enclosure of any electrical equipment must earthed effectively for human safety.
Manindra.
Manindra
Register to Reply 6 comments
lyn (1); manindra (1); mohsinhamid (1); pandan27 (1); pnaban (1); PWSlack (1)
