Previous in Forum: NASA’s Next Giant Leap   Next in Forum: Military, Weapon, and Armament Technology
30 comments
Good Answers: 61
Thrust Without Fuel
08/04/2014 4:48 AM
Here's a mighty interesting invention/concept:
http://www.gizmag.com/cannae-reactionless-drive-space-propulsion/33210/?utm_source=Gizmag+Subscribers&utm_campaign=5c48ebf212-UA-2235360-4&utm_medium=email&utm_term=0_65b67362bd-5c48ebf212-90567161
What worries me a bit is this:
"Even beyond that, Shawyer claims that the second generation of his fuel-less thrusters, based on superconductor technology, will be capable of producing an impressive specific thrust of 30 kN per kW of input energy. "Thus for 1 kilowatt (typical of the power in a microwave oven) a static thrust of 3 tonnes (3.3 tons) can be obtained, which is enough to support a large car. This is clearly adequate for terrestrial transport applications."
1 kW could yield 3 tonnes of thrust? I don't get it!
Pathfinder Tags: Thrust no fuel
Good Answers: 61
Re: Thrust without fuel
08/04/2014 6:51 AM
Replying to myself: This whole thing smacks of Pons/Fleischman's Cold Fusion claims.
08/05/2014 3:07 AM
Really? Not bullshine as well, then?
08/04/2014 8:04 AM
Firstly, a kilowatt is not a unit of energy; it is a unit of a rate of energy.
Secondly, a magnet can develop such a thrust, without using any power at all.
So the odour of bovine excreta should be all-pervading.
08/04/2014 8:08 AM
Without fuel???
Errr but it says an input energy of umpteen kW of electricity.
If electricity isn't fuel why am I paying for it back here on Earth?
Good Answers: 61
08/04/2014 10:02 AM
Thrust without propellant. There is still energy input.
08/04/2014 10:04 AM
Its units don't make sense as written.
Good Answers: 92
Re: Thrust Without Fuel
08/04/2014 9:58 AM
Totally agree with you that there is no supporting evidence for Shawyer's statement- note that it is clearly a projection, not a statement of having done so- but what did you expect from gizrag?
On the other hand, the Phoenicians managed to build an empire with reactionless drives (OK, not truly so but according to the definition in the article it would be!!).
08/04/2014 10:05 AM
A weight at height could produce thrust. Something doesn't make sense.
08/04/2014 10:13 AM
This article makes no sense to me. A resonant cavity can accelerate bursts of charged particles very nicely. The only thing this article discusses is the radio frequency energy pumped into the cavity, there is no mention at all about charged particles. Are all of these fantastic claims of thrust purely from the RF photons produced? Then there's the preposterous leap of four decades of magnitude for switching to a superconducting cavity with similar power applied. That normal conduction cavity had to be getting really hot to be wasting that much power.
I guess Gizrag once again mangled another scientific paper.
08/04/2014 11:11 AM
I would have to say I'm skeptical. I have a deep seated religious belief in the Law of Conservation of Momentum.
08/05/2014 3:06 AM
One could always add-in the Laws of Thermodynamics!
08/04/2014 12:36 PM
Engage the warp drive Scotty....
I canno make 'er go without the dilithium crystals captain...
08/04/2014 4:03 PM
Is that Conan O'Brien at Uhura's communication station?
08/04/2014 3:56 PM
The phenomena seems to be real, but the claims by the inventor of thrust output are orders of magnitude higher compared to what has actually been physically replicated in the lab.
Are superconductors the new anti-gravity over-unity pseudoscience engine?
08/04/2014 7:15 PM
OK, I'm trying to make my microwave oven levitate. What am I doing wrong?
08/05/2014 3:10 AM
Not enough RDX, in all probability...
08/04/2014 8:03 PM
Here is a paper on the theory of operation...
http://www.newscientist.com/data/images/ns/av/shawyertheory.pdf
08/05/2014 9:54 AM
The first thing I see is that the side forces, Fs1 and Fs2, in fig 2.4 are vertical whereas the sides are not horizontal. It seems to me these forces should be perpendicular to the surfaces, in which case I believe the forces cancel and Conservation of Momentum lives to see another day.
08/06/2014 5:58 PM
I have trouble reconciling the simplicity of the paper with NASA's results. The paper is at a 2nd or 3rd year college level; not particularly deep in terms of its Physics. It seems odd that the author tries to be rigorous with his math and graphs, but includes a very poorly drawn diagram that does not properly reflect (no pun intended) the ray traces of the microwaves.
Like this. The blue line shows the path when the correct angles are used for the reflections.
Yet, NASA claims they got positive results? Makes no sense.
08/07/2014 10:05 AM
My understanding was that it was done in air because a HV power supply had an Electrolytic capacitor that was not certified for vacuum. Vacuum tests are being planned.
http://blogs.discovermagazine.com/outthere/2014/08/06/nasa-validate-imposible-space-drive-word/#.U-OFGPldWSo
It's a nice dream, turning energy into momentum. Lots of energy can be had from nuclear power, but due to the conservation of momentum, when a rocket engine runs out of stuff to throw out the back, that's all the momentum you're going to get.
I'm still betting on the Conservation of Momentum.
08/07/2014 10:18 AM
Maybe they intend on gathering interplanetary particles [solar wind, dust, etc.] and accelerating them with this resonant cavity. Kind of a jet engine like approach but relying on the fact that space is close but not actually an ideal vacuum.
08/09/2014 10:04 AM
Sort of like a Bussard Ramjet?
http://en.wikipedia.org/wiki/Bussard_ramjet
08/09/2014 10:25 AM
This is another interesting idea for sailing the solar wind...
http://earthweb.ess.washington.edu/space/M2P2/
08/10/2014 7:45 PM
I like the way Physicist John Baez put it:
"this is about as plausible as powering a spaceship by having the crew push on it from the inside."
08/10/2014 11:04 AM
NASA also claims AGW is alive and well
Good Answers: 32
08/04/2014 11:01 PM
Whats this 30kN stuff? The article says between 30 and 50 micro-Newtons."
johny451
08/04/2014 11:07 PM
Keep reading, the bizarre claims are in the second to last paragraph of the article.
Good Answers: 143
08/05/2014 6:06 PM
Aye, it's that static thrust thingy. My garage floor exerts a static thrust of roughly 1 ton, and uses no power at all. If I wanted it to be warm so I wouldn't freeze my buns when I'm lying on it trying to run oil into my eye, I could embed some heaters, and then it might exert a ton of static thrust for 1200 W of power.
Mixing units of power and force is about as sensible as saying that the big rat snake who lives back of me kills two rodents a week, and has a laundry bill of less than $0.14 a year. In other words, if a claim don't make sense, grab your women, your liquor, and your money, and run away - he's after at least one of 'em.
08/05/2014 11:43 PM
My guess, once this has been thoroughly investigated, is that they'll find one end of the cone gets slightly warmer than the other end, causing the air to expand and push on the device. So heated air will be the actual cause of the thrust. (Note that even in the 'vacuum' chambers they used, there is still a trace amount of air.)
08/06/2014 7:28 AM
This thread is just making me a little twitchy.
Reply to Forum Thread 30 comments
energyconversion (2); jack of all trades (2); JNB (1); Johny451 (1); JWthetech (1); PWSlack (6); redfred (4); Rixter (8); SolarEagle (1); TVP45 (1); Usbport (2); user-deleted-1105 (1)
