Previous in Forum: Standards for Specifying Anti Skid Coatings to Steel   Next in Forum: How to Measure Total Concentration Indirectly
16 comments
Using Aqua Regia to Refine Silver
08/09/2014 12:36 PM
Hey I have a couple hopefully pretty quick questions.
I have been working with scrap electronics for a while now to get silver and gold. Up until now I have just been going for the gold and setting the silver products aside. (not counting the silver chloride removed from aqua regia during gold purification) Well now I am wanting to start working on refining my silver. Up until now I have been using nitric acid to disolve the silver off of keyboard mylars then cementing the silver out using copper. I've been extremely pleased with the amount of metal gotten from this and would like to continue the process but I am running out of nitric and have hundreds of mylars left to go.
I was trying to think on some ways to either re-use the nitric or just go a different route entirely. I took a batch full of now copper nitrate and attempted to electroplate the copper out but the nitric attacked my stainless steel anode and ruined the solution. I know I could use gold for my anode but the gold I have I scrapped from the electronics and is not nearly as prevalent as the silver so is much harder to get large quantities of. Also the gold nuggets I have are not .999 as the nuggets only went through 1 AR bath to get to thier present state and as such will proly not survive the electroplating process as I would think it should. So until I can purify the gold a bit more I am discounting the use of a gold anode.
I was thinking that it would be possible to dip the mylars into an AR bath and just have the silver chloride fall to the bottom off of the mylar. Now there are a few things wrong with this that I can think of. First do you think the silver will form a passivation layer even though there is nitric present? if it would then that throws off the whole idea. Also this process should use up the HCL rather than the nitric and allowing me to just keep adding HCL to the batch as I remove the silver chloride. I have gallons of HCL left and only a few hundred ml of nitric left so if this is the case then it would be ideal.
Would this work like I think? If not do you guys have any other ideas to remove the silver from the mylars? I mean I know I could just burn the mylars down until I have nothing but silver left but that is an absolute last resort for me.
Those who are afraid of the dark has never seen what the light can do.
Re: Using aqua regia to refine silver
08/09/2014 12:55 PM
has this method been cost effective so far?
08/09/2014 1:54 PM
interesting topic, some might be helped with this
08/09/2014 12:55 PM
If this is a "pretty quick question", I shudder to think what a complicated question would look like.
What is the scale of your salvage operation? I see 55 gallon drums of scrap mylar to yield a gram of gold.
Waste disposal is also troubling me.
I do not claim to be able to offer you any meaningful help. My only contact with HCl is when I pour it in my swimming pool.
08/09/2014 1:04 PM
Using straight nitric acid isn't very cost effective no. That is why I am looking for an alternative in the form of some sort of re-usable solution. As for the silver output it is much better than the amount of gold I have been getting. Each batch of nitric (150-300ml) get me around half an ounce of silver. I have run through so many mylars it is hard to say how many I've done but I'm not even 1/10th through all the mylars so I have a ways to go.
Re: Using Aqua Regia to Refine Silver
08/09/2014 8:02 PM
My best advice is to hire a pro in the field of inorganic chemistry. He / she will design the easiest, most efficient, safest and environmentally friendly process for you to implement. At my company we deal with both: organic and inorganic compounds, and I went that way to improve some obsolete and inefficient processes (also had to struggle against prejudice, cause they have "always" been done that way). The results have been highly rewarding!
08/09/2014 11:10 PM
If you prefer electroplating, try a graphite electrode. Otherwise, copper sulfate mixed with con. sulfuric acid and a little heat will yield nitric acid and leave copper sulfate.
Good luck. GH
Good Answers: 128
08/11/2014 10:33 PM
Friend,
I don't see where the nitrate comes from in your verbal equation. Please advise us.
--JMM
08/11/2014 11:16 PM
You are right, I mis-spoke. I should have said copper nitrate plus con. sulfuric acid. The OP indicated he had lots of copper nitrate. Sometimes my brain takes a break when I start typing.
GH
Popular Science - Weaponology - New Member Canada - Member -
Location: In the sticks of the Central Kootenays, BC, Canada
08/09/2014 11:29 PM
Have you looked at the "gold refining forum"? They specialize in gold and precious metal recovery. They are also safety Nazis, so anything that looks like a dumb question will get you flamed, tarred and feathered, whipped and rolled in salt, and given a tongue lashing by someone who makes Lyn look tame.
But they seem to know their stuff.
There is also a book available on line by Hoke, called something like "refining of precious metals" It's a free download, and you can find it on that same forum.
Jon.
PS: The link is:http://www.goldrefiningforum.com/
I couldn't get the link tool to work in the editor.
08/10/2014 8:25 AM
When entering a link, it won't work (as a link) until you go to "Preview Comment". You can test it, and still go back to do more edits before posting.
Good Answers: 203
08/11/2014 8:34 PM
Suggest you do a cost analysis on your present process and any future ones. You seem to be generating a lot of waste chemicals. The USA is the most costly place to correctly dispose of direct process waste and also secondary process waste. For all the work and chemicals being used you might be giving the stuff away and not know it. The fines for illegal disposal are real steep and only one incident for a violation you never heard of could put you in the poor house.
Another more important item is the personal protective equipment that everyone needs to wear. Nitric and Hydrochloric acids are real bad ones requiring some expensive PPE and personnel must be protected. Same with these fines.
Good Luck, Old Salt
08/30/2014 9:37 AM
You could start out with a keyboard mylar, attach it to positive electrode of voltage supply, and a silver foil attached to the negative (ground) electrode. There has to be an electrolyte and HCl is OK, as long as you do not overdrive the voltage through electode polarization and make chlorine. Electrowinning has many side benefits: (1) it helps purify the metals (this is how raw smelted copper is purified to high grade copper), (2) does not involve aqua regia that is extremely hazardous to work with, and will poison you with NOx if you breathe the brown gas that is emitted, and (3) can be applied to metals containing both silver and gold, where sometimes the gold simply drops out of suspension near one of the electrodes.
With some fine tuning you might learn that you have less work to do cleaning up and separating the yield. I think there are even companies out there that specialize in selling the equipment for this. Be aware that electrowinning may consume considerable electric power, and may be slower than you are used to dealing with.
08/30/2014 2:35 PM
I thought about electroplating it off but found that the plating would take the silver off unevenly. It would break contact with the part hooked up to power and leave over half the silver on the mylar. I usually try to electroplate when really needed such as when I purify copper or cobalt as well as the molten salt plating for calcium, sodium, lithium and aluminum. I will after getting this silver shot done pour it into an anode and then plate it over to increase the purity. It is just the process of getting it off the mylar that is the kicker.
As for the original question I found the aqua regia does work a little bit but isn't any more cost effective. Also I re-read an earlier post and I should have said 15-30ml not 150-300ml for a half ounce.
I have since decided to move in the direction of making nitric acid to use on the silver rather than finding an alternative way of stripping it. It isn't so hard to make and sodium nitrate is much cheaper than buying straight nitric.
08/30/2014 7:47 PM
Half an ounce (14g) of silver from 15ml (three teaspoons) of reagent? Really?
08/30/2014 9:51 PM
Give or take, yea. Nitric can hold quite a bit of silver in it. I also said 15-30ml as well.
09/03/2014 9:42 AM
Have you even considered destroying the mylar?
Total glycolysis, methanolysis, and hydrolysis[edit]
The treatment of polyester waste through total glycolysis to fully convert the polyester to bis(2-hydroxyethyl) terephthalate (C6H4(CO2CH2CH2OH)2). This compound is purified by vacuum distillation, and is one of the intermediates used in polyester manufacture (see production). The reaction involved is as follows:
[(CO)C6H4(CO2CH2CH2O)]n + n HOCH2CH2OH → n C6H4(CO2CH2CH2OH)2
This recycling route has been executed on an industrial scale in Japan as experimental production.
The above was copied and pasted from a Wikipedia article on PET, of which mylar is a particular sub-class. Sometimes the Mylar is modified by coating or treatment to make the polymer less crystalline (makes it more flexible and is more resistant to cracking). If you wish to recycle the Mylar, it makes about as much sense to break it down, filter off the silver (and any other metals if they are present), and then sell the clean "monomer blend". IF you only wish to destroy the Mylar, then try using caustic soda bath at high concentration, to (a) partially hydrolyze the Mylar and slough off the silver, or (b) totally dissolve the Mylar, and if insoluble have the monomers float off, and the silver sink to the bottom. I think it could be worth an experiment. I would like to get a cut of the action on this if it works.! Good luck.
Register to Reply 16 comments
Fredski (2); Gene Hayes (2); Jack Puddin (3); James Stewart (2); jmueller (1); JohnDG (2); lyn (1); old salt (1); r&ddoc (1); sawmilleng (1)
