Previous in Forum: Safest Method to Lock a Fan on a Fin Fan Cooler from Rotating Due to Wind   Next in Forum: A Little Energy Puzzle
Branch Reinforcement Calculation
08/13/2014 5:22 AM
how to find wheather branch reinforcement needed or not if needed how to calculate as per asme b31.3 ?
Nps 24 header to Nps 12 branch
Dh =24.01in. Db = 12.74in.
Th =0.688in. Tb= 0.4 in.
design pressure 251 psi
stress = 20000 psi
y = .4
E = 1
corrosion allowance = 0.177 in.
mill tolerance 12.5%
Re: Branch reinforcement calculation
08/13/2014 5:55 AM
It is better to have and not need, than to need and not have.
Re: Branch Reinforcement Calculation
08/13/2014 12:22 PM
The language to describe all of this is perhaps too fine-tuned to give in a brief Web post. Basically, the cross-sectional area you cut out of the main pipe must be replaced somehow. This can be done by surplus thicknesses of header and/or branch, addition of a reinforcement pad, some extension of the branch (or vessel nozzle) into the main pipe (or vessel shell), and weld cross-sections. There are five areas involved.
An easy, but sometimes too conservative, way to address this is to provide a reinforcement pad of thickness equal to the vessel wall or main pipe, with outside diameter 2x the branch or nozzle diameter.
Good Answers: 104
08/13/2014 1:47 PM
Do you have a copy of B31.3? If so, this is pretty much cookbook. If not, get it.
Ed.: but I'm guessing reinforcement will be required. Post back when you calculate the answer.
08/14/2014 3:08 AM
My own guess might (not necessarily would) go the other way. On quick glance, the pipes seem to be well thicker than needed; this could give some surplus cross-sections that might be adequate without reinforcement. I don't have the B31.3 standard to hand, and don't know how closely it matches the pressure vessel code.
As the saying goes, don't try this at home. Find out and follow the correct calculations.
Register to Reply 4 comments
bigg (1); PWSlack (1); Tornado (2)
