Previous in Forum: Resistor in the Place of a Removed 4-20mA Loop Powered Instrument   Next in Forum: RTD & Thermocouple
Temperature Compensation
08/13/2014 1:25 PM
Why we need temperature compensation in flow measurement of steam?? if i do not use temperature compensation then how accurate flow value will be??
6
Re: Temperature compensation
08/13/2014 1:59 PM
The density of steam varies with both temperature and pressure. If temperature compensation is not used, then the flow reading will be inaccurate and the range of inaccuracy can be estimated using published Steam Tables and some arithmetic.
Reply Good Answer (Score 6)
Reply to Forum Thread
