Previous in Forum: Capacitor Bank Connected Parallel to Motor   Next in Forum: Alternator Unable To Supply Power To Welding Machine
21 comments
Aluminium Tape Over Ignition Coil
08/18/2014 12:51 PM
A plastic engine cover "Eco Tec" over the ignition coil assembly (4 plugs) is missing on a car. If I cover the coil instead with an aluminium adhesive tape - to prevent dirt getting inside, could not the coil induce some current in the tape and get damaged ?
Re: aluminium tape over ignition coil
08/18/2014 12:55 PM
will not cause a current or affect viltage
08/18/2014 1:16 PM
Thank you ! It would be fine as the damned thing (both new or used) could not be found at our place. And the aluminium foil tape is much stronger than a grey or black plastic tape.
08/18/2014 1:26 PM
08/18/2014 1:24 PM
I need to start proof-reading my posts
09/25/2014 11:37 AM
Salut viltage! More Soviet music this morning?
Re: Aluminium Tape Over Ignition Coil
08/18/2014 1:45 PM
Why not just get one from the junk yard, or Ebay...?
08/18/2014 2:05 PM
Why not temporarily the alumi tape if the cover's unavailable ?
Good Answers: 67
08/18/2014 2:15 PM
Why start this thread when your mind's already made up?
08/18/2014 2:24 PM
Why teach not knowing answer ?
08/18/2014 3:09 PM
How do you know that he doesn't know the answer?
In America, we sometimes believe it's better to ask forgiveness than ask permission.
So if this is what you want to do, go ahead if you can live with the possible consequence of failure. What's the worst that could happen?
Good Answers: 67
08/19/2014 1:12 AM
A passenger plane might fall on his convoy?
08/18/2014 6:38 PM
It might come loose and cause bigger problems.....Why are you opposed to fixing it properly?
08/18/2014 7:21 PM
I'm not opposed to fixing it properly.
Your photo shows the entire engine cover assembly while I believe the coil cover is the narrow, center cover.
Until the proper cover can be installed, tape would be better than nothing.
08/18/2014 3:37 PM
You may have a problem with the adhesive on the tape melting and causing a mess.
Mr.Ron from South Ms.
08/18/2014 4:25 PM
Use the Al tape. Don't let it touch anything electrical.
Don't worry about induced currents.
09/25/2014 11:42 AM
He needs to make and get the Aluminum tape from Lyndoor Industries that has the non-conductive, high dielectric constant adhesive. Otherwise who know? It could work. If it does induce current and burn the car down, then what Yuri? I assume you cannot find the original cover, and cannot order a new one on Ebay? Then find another car with one, grease it with vaseline petrolatum or wax, and apply Smoothe-On pourable castable epoxy, and make a new one.
09/25/2014 1:27 PM
You may find it strange but I have not driven the car since.
Just in case, should indeed change for something else the Alu scotch I stuck very properly then.
08/18/2014 11:01 PM
Cut a plastic food container to the shape and stick it down with the tape. Use a microwave safe container for better heat resistance.
Good Answers: 39
08/19/2014 12:51 AM
My first instinct would be to think about splash and condensation water trapping. Then I'd worry about my reputation as a mechanic. Are you on a convoy in Ukraine?
Align culture with nature...
08/19/2014 12:10 PM
Thank you for the useful, and non-biting posts !
Good Answers: 67
08/19/2014 4:33 PM
(psst: You are replying to your own post)
Register to Reply 21 comments
Doorman (1); europium mkII (3); Fredski (3); James Stewart (2); JIMRAT (1); lyn (2); ormondotvos (1); ronseto (1); SolarEagle (2); Yuri B. (5)
