Previous in Forum: Sewer Gas / Independent Living Home   Next in Forum: Central Electrode of Spark Plug
Wire Rope Sag And Tension Calculation
08/21/2014 12:30 AM
Hi! I would like to know how to calculate the sag and tension on wire ropes. I just need it to calculate a Dyneema rope sag that will be used as a cable way with a payload of 0 and 50 pounds at 20% of the maximum breaking strength tension at normal summer temperatures.
How does the weight and diameter of rope itself affect sag?
Thanks in advance for your concern.
Pathfinder Tags: sag
Re: Wire rope sag and tension calculation.
08/21/2014 12:42 AM
Have you contacted any wire rope suppliers?
Looked on the web for, "Wire rope sag and tension calculation" sites?
I just did and found 71,300 results.
You should try it.
If you are not successful, maybe some member will help you.
Home | Dyneema ®
08/21/2014 4:15 AM
A free-hanging rope suspended between two anchors responds to mathematical analysis. The shape function is the hyperbolic cosine.
Most textbooks on Mechanics contain at least some reference or analysis. Get reading!
Re: Wire Rope Sag And Tension Calculation.
08/21/2014 10:30 PM
The supports at each end will have an upward component equal to the weight of the cable and the wire rope. The tension component you are specifying as 20% of maximum breaking strength. This gives you the angle of the cable at each support, arcsin(.5*wt/tension).
The curve the sagging cable makes will be a catenary or hyperbolic cosine. The derivative (slope) of the hyperbolic cosine is the hyperbolic sine, which you know as the angle of the cable at the support.
Take the inverse hyperbolic sine of the slope, and then the hyperbolic cosine of that value to find the vertical distance from the support to the minimum point of the cable sag.
That's the best I can tell you without a drawing.
08/21/2014 11:08 PM
Find equations for a catenary. I don't have them handy anymore, but those will provide what you need. Is this an outdoors installation? If so, don't forget about the loading due to ice and wind, and wind on ice covered cable. Temperature will affect the tension.
Lehman57
Register to Reply 4 comments
Lehman57 (1); lyn (1); PWSlack (1); Rixter (1)
