Previous in Forum: Central Electrode of Spark Plug   Next in Forum: Chlorine & Hydrogen Psychrometric or Mollier Chart
Baffle Material In S & T Exchanger
08/21/2014 5:54 AM
shell and tube heat exchanger if shell side wet H2S(Hydrogen induce cracking) is required then is it necessary to consider HIC plate for baffles.
User-tagged by 1 user
Re: baffle material in S & t exchanger
08/21/2014 6:16 AM
One could also consider the same material as forms the shell and the tubes, as well as a range of other materials, without some idea of temperatures and pressures.
Engineering Fields - Chemical Engineering - New Member
Re: Baffle Material In S & T Exchanger
09/01/2014 6:08 AM
Please use ColePalmer material compatibility online database, however if I can recall Titanium would suffice your needs
Chemical Engineers are like high Temperatures & high Pressures
