Previous in Forum: Samanta   Next in Forum: How To Rectify Supply When 3 Phase Supply Gets Reversed From Grid End?
31 comments
Amps Drawn By A Ford Type Relay
08/25/2014 12:48 AM
Hello! the Kohler gen-set on my boat has a On - OFF Perko battery switch on the + lead of the battery, which is placed in a quite unreachable spot. Moving it somewhere else implies to install a quite long run of cables, which I prefer to avoid for safety reasons and cost. I would like to replace the Perko switch by a Ford type relay:
in order to command it by means of a switch on the dashboard (which will be -by far more practical) I need to know the amps drawn by the relay´s coil in order to install wires of the correct gauge (the run is of about 10 meters). Unfortunately there is no label on the relay indicating this, and I have not found it either searching the internet. Common sense indicates it will probably be under 3 Amp... but wouldn´t bet on that! Does anyone know this? Would it be of help to calculate it by measuring the Ohms of the coil? Can such a relay remain connected during a long time span, while the gen-set runs (perhaps 5 hours on a row?). Thank you a lot!
Re: Amps drawn by a Ford Type relay
08/25/2014 1:34 AM
Here's a nice informative discussion on that....
http://www.bcae1.com/battiso.htm
Amps = Volts / Ohms
The Ford type starter solenoid is not rated for continuous duty and will overheat....they do make continuous duty solenoids for this purpose, the ohms of resistance are much higher, making amp draw much smaller.....
A battery combiner seems to be the way to go....
"The bottom line here is that today, a modern solid-state battery combiner is the best way to go for this application. They have minuscule amounts of voltage drop and do not generate the heat levels that the diode-type isolators do. Companies like Balmar, Blue Sea Systems, Charles Industries, Newmar, West Marine and Xantrex all produce suitable battery combiners today. Diode-type battery isolators are a lower cost alternative that is fraught with compromises, but still used in OEM installations to save a few dollars."
http://blog.boats.com/2012/12/marine-battery-isolators-old-types-versus-new/#.U_rMTfldWSo
http://www.thehulltruth.com/marine-electronics-forum/3307-battery-isolators-vs-combiners.html#b
Source....
http://www.hellroaring.com/
08/25/2014 2:30 AM
08/25/2014 5:46 AM
I agree that you need a continuous duty relay. I use one with my dual batteries in my truck, and it draws less than 10 Amps.
08/25/2014 7:36 AM
Thanks a lot for the thorough info! Very interesting sources!
08/26/2014 12:26 AM
Right on!
"Real Bass Players" do not use picks
Good Answers: 444
08/25/2014 1:39 AM
Yes, for steady state current in a DC circuit you can use your ohmmeter to find the coil resistance for use in Ohm's Law to calculate the current, but why not use the Amp function on your multimeter and measure the current directly?
The bigger question is whether the relay coil is meant for continuous duty; you might try to energize it from your battery and see how hot it gets over time. If it heats up fast and gets too hot to touch you're out of luck.
I don't what type of boat you have, its fuel, and exactly where this relay is going; but make sure you run the bilge fan before you push that button!
08/25/2014 7:38 AM
Thanks to you too! The boat is a twin engine diesel, so gasoline fumes are not an issue!
Good Answers: 67
08/25/2014 1:48 AM
As this is a starter solenoid, it is designed for intermittent operation. Running it continuously is not advisable; you will end up replacing it in short order, guaranteed. Attempt to power the coil continuously for five hours and you will smoke it.
If you can find a good quality latching relay, you'll be way ahead of the game as these take a short pulse to toggle them on and off (depending on the design). However, high-current latching relays are expensive - more so than the length of cable you're trying to avoid running for reasons of safety and cost.
But, as this is a high-current application - I'm guessing 100-200 amps? - it's best not to cut corners. If it's safety you want, it will come at a price. As an example, a new, 200-amp latching relay costs around $300. Interestingly, DigiKey sells a 200-amp, non-latching automotive relay for $615. Go figure.
Perhaps if you told us what sort of current you expect to pass through this relay? What is the Perko switch rated for?
08/25/2014 9:35 AM
Hi! the Perko switch is rated 100 A.
Good Answers: 67
08/25/2014 11:29 AM
Thanks. Be sure to use a relay rated for *at least* 100 amps and one suitable for marine service.
08/25/2014 11:50 AM
right!, thank you again!
Good Answers: 67
08/25/2014 12:16 PM
You're welcome! Lots of good info on this thread so you have no problem finding what you need.
08/26/2014 4:34 AM
GA for your good post.
Alter your 5 hours to maybe 5 minutes - tops.....
The OP should NOT go with a relay, any relay, that is adding a further P.O.F. and that is the last thing you need on a boat......
He should "Bite the Bullet" and move the switch to a better position, or simply add a mechanical way to turn it on and off if you cannot reach where it is now.
Re: Amps Drawn By A Ford Type Relay
08/25/2014 8:24 AM
08/25/2014 9:57 AM
Seem to have very affordable products. Thank you!
08/25/2014 10:19 AM
sure
Good Answers: 122
08/25/2014 9:56 AM
I would not consider any DC relay and/or associated control equipment for this application on a boat other than one that is designed and rated for "Marine Service".
Although the cost for marine service rated devices is higher, the reliability is worth the expense.
If you are quarantined to using the boat on small fresh water lakes the risk is small however if the waterway is large or if the boat is going to be used at sea, your safety risk is great.
There is a myriad of marine rated manufacturers available on the internet that provide the equipment and parts you need to make this revision in a safe, reliable manner.
08/25/2014 6:26 PM
Searching locally I have found this 1500 W (125 Amp in 12V) solenoid for the equivalent of 100U$ a piece. It is sold under the Bull Winch trade mark. Could not find any specific info besides the wattage. Due to it´s shape, one could consider it works by means of diodes, instead of a coil as the Ford type. What do you think?
08/25/2014 6:39 PM
is it marine rated?
08/25/2014 6:48 PM
It should be. Will call the store tomorrow. These guys sell marine stuff (which is a good start!) Thanks!
08/26/2014 1:23 AM
This switch is manufactured here under the name Baron USA....this is a windless reversing solenoid switch for raising and lowering the anchor...it's not used in your type of application, nor would it be suitable....keep looking
http://www.baronusa.net/articulo/solenoid-reversing-12v-4-wire-max-1500w/3292
08/26/2014 10:39 PM
Baron is a well known outfitter here in Argentina, specialised in yachting This company also has some stores in the US. The picture I posted is of a part sold by a local competitor, but seems to have been done by the same manufacturer. I visited the store this afternoon, and yes it is of no use in my project. Thank you a lot!
Good Answers: 122
08/26/2014 5:08 PM
Diodes could not and would not interrupt the DC power.
It appears to be a hermetically sealed relay of significant current handling capability.
The factory wiring diagram/schematic should be available from the manufacture in pdf or other picture format for viewing the internal parts.
08/25/2014 6:40 PM
Good Answers: 225
08/25/2014 11:29 PM
Consider a solid state switch.
There are power Mosfets available that are capable of switching around 300 amps with no sparking, so no fume control considerations, and, because they are voltage operated, with little to no current in the gate control circuit (other than for maybe an indicator LED if desired), voltage drop on the control line is virtually nonexistent.
In a straight switching mode such as this, ie. either on or off, very little power will be dissipated by the device, so little heat will be generated.
Just about any competent electronics tech. should be able to make one up for you in very little time, and at probably less cost than the relay. For example, an IRL3713SPbF N channel Mosfet will carry 260 amps continuous (maybe a bit less at elevated engine room temperatures, but 2 in parallel would easily do the job), one can withstand an inrush of a tad over 1000 amps, will handle up to 30v with max 20v on the gate and cost you around $5, the tech's time will be a bit more but the circuitry is pretty simple.
Cheers
Good Answers: 39
08/26/2014 3:04 AM
You have diesels. Does the starter cranking current go through this switch? What is the cranking current? Some diesels exceed 800 amps. Some diesel fumes from some places are diluted with gasoline by idiots. All marine switches, especially in the bilges, MUST be sparkproof. Large mechanical switches can be remotely operated mechanically, by a rod in a tube, cable, etc. If a starter solenoid sticks while cranking, you need a quick way to cut the batteries out. (I once saw a logger literally axe-cut the cable on a forklift when this happened. Sparky!!!)
Align culture with nature...
08/26/2014 4:37 AM
GA
08/26/2014 7:28 AM
Hi, The remote operated swich I am looking for is ONLY to connect / disconnect the + prower supply from the battery to the genset.
The cranking current for the main engines is provuded by a completely separated battery bank. The diesel in the tanks is just that (no mixing with any other fuel)
08/26/2014 1:58 PM
Actually, although Diesel is difficult to light till over 40°C or so, the fumes will explode very easily, when you smell Diesel, you are smelling fumes......
.......as they are often mixed with air.....its still a risk, but nowhere as bad as Petrol fumes of course!!
See Post #6 on this website:-
Diesel-fumes-are-explosive
Of course diesel is safer than petrol, but you still have to play safe. A warm engine room (where many tanks are fitted) on a hot day may cause diesel to gradually fume...therefore its always worth purging the bilge before starting....
Never treat diesel lightly (pun intended!).
08/26/2014 5:02 AM
Dear OP, simply do not do this. Either do a proper job of moving the switch to a more accessible place, or extend mechanically the switch.
I thought about this and a simple way to do this type of mechanical extension might be using say one of those cheap drain cleaner wires, which can be as long as 10 foot, which are quite stiff in twisting, guide it gently via a few "P-Clips" and use it to "remotely" switch the battery switch....
Here is one:-
Coating it occasionally with WD-40 will stop rust and allow easy movement. Try to keep it as "straight as possible. A flexible plastic tube may be even better....
I have never done it myself, and a certain amount of "tuning" may be needed to get it just right!!
But a REALLY cheap and unlikely to break down mechanical method.....
It may not be possible to bring it to where you sit, but is that needed? I doubt it....
Remember, if your electrical system EVER needs this switch in an emergency, then something is wrong with the boat's electrics anyway....get that fixed first before moving the switch or adding a remote control.....
Its bad enough having relays/solenoids to start your engine on any boat/car/truck/etc., simply don't add anymore of them to your boat when safety is critical.....
08/26/2014 7:37 AM
Dear Andy, thanks for your input, and concern! I do subscribe to the KISS idea and fully agree with you about safety. This only involves a (non critical) 220V generator. Given the case the realy / solenoid does not work, there is always the possibility of working a little bit in order to by-pass it.
Register to Reply 31 comments
Andy Germany (4); europium mkII (3); Fredski (4); Jimh77 (1); ormondotvos (1); r&ddoc (10); RAMConsult (1); SHOCKHISCAN (2); SolarEagle (3); spades (1); Tom_Consulting (1)
