Previous in Forum: Failure Analysis of a Failed Steel Rope   Next in Forum: Engine Dead Because of a Lub Oil Drain Valve
9 comments
How To Clean the Engine Bay?
08/30/2014 1:26 AM
Summer coming up so gonna give the car a good going over. What is the best way to clean the engine bay?
Thanks
MRO Supply
Re: clean the engine bay?
08/30/2014 2:34 AM
Steam....lacking access to steam, then Gunk and hose it....cover electrical components with plastic....let dry thoroughly before restart....compressed air to blow water off a +...
http://www.pressurewasher-steamcleaner.com/engine-steam-cleaner.html
08/30/2014 8:24 AM
08/30/2014 1:58 PM
Quarter car wash, which now costs two dollars.
Re: How To Clean the Engine Bay?
08/31/2014 9:36 AM
How about going over to the toothpaste thread?
http://cr4.globalspec.com/blogentry/25206/Toothpaste-Debunked?frmtrk=cr4digest&et_rid=534021123&et_cid=63393126
Toothpaste seems useful for cleaning and polishing everything.
08/31/2014 3:37 PM
You get someone else to do it for you.
How dirty is it anyway?
09/27/2014 11:04 AM
since he is cleaning the engine "bay", I suggest using oil booms, or whatever BP uses.
09/01/2014 11:57 AM
Know anyone with a dry ice blasting machine? Great engine cleaning tool, no need to cover electronics, clean everything including the batter, electronics, hoses, etc. You can clean a entire engine auto engine compartment with about $10-15 (10-20 lbs) in dry ice. This may not be practicle for your use as you need a large compressor (185), a dry ice blasting machine, and dry ice which usually need ot be ordered ahead of time and, if delivered, minimum delivery quantity is typically 500 lbs. This is why if you know someone that has a machine they probably will have everything else needed also and will be the only practicle way to clean one auto engine compartment.
Providing cleaning solutions for industry
Good Answers: 29
09/03/2014 7:33 AM
FYI, don't EVER use a pressure washer to clean an engine.
A former co-worker of mine thought it would be a cool idea. F-ed up his Jeep Wrangler with an intermittent electrical problem. After replacing half of the electrical system, including the ECU, he gave up and traded it in. Let the next guy figure it out.
If you see a 2000 red Jeep Wrangler on the market cheap, don't buy it.
09/03/2014 3:37 PM
Oh how very ethical, hope he used it as a trade in that was then scrapped.
Guess we will find out soon when someone starts posting on CR4 about their intermittent electrical problems with their new red 2000 Jeep Wrangler they just brought. You can handle those. Awkkkkkward.
Register to Reply 9 comments
Dry ice blaster (1); Fredski (1); jack of all trades (2); James Stewart (1); Lo_Volt (1); lyn (1); phph001 (1); SolarEagle (1)
