Previous in Forum: Gluing Plexiglas to Stainless Steel   Next in Forum: Signatone Prober Needs A Belt
10 comments
Rubber Conveyor Belt
08/30/2014 8:25 AM
Hi
can some one share technical standard/ nomenclature regarding rubber conveyor belt
for example i have seen one belt which is showing EP150 W610X10mmx4ply
EP STAND FRO?
4 PLY MEANS?
hope to have reply
thanks in advance.
Re: Rubber conveyor belt
08/30/2014 9:00 AM
Why on earth don't you phone the supplier and ask?
Good moaning!
Good Answers: 69
08/30/2014 9:19 AM
Because obvious solutions are forbidden in this world, the common sense is dying and unprofessional professionals are taking over the world.
Damn ! I'm grumpy this morning...
08/30/2014 1:43 PM
08/30/2014 1:48 PM
I'm going back to "In Search Of Intelligent Life, Somewhere; Anywhere." for my tag line.
So far, none has surfaced, at least not here!
I had to get up at 4:30 AM. I'm really grumpy!
08/30/2014 10:25 AM
plys
08/30/2014 1:11 PM
EP may be ethylene propylene.
08/30/2014 1:39 PM
Go here: Search GlobalSpec
Type " EP150 W610X10mmx4ply flat belt" into the search box.
Re: Rubber Conveyor Belt
08/31/2014 11:23 AM
EP150 is likely just a manufacturer number.
W610 is the width in MM.
10mm is the thickness in MM.
4 ply is the number of "sheets" of materials compiled to make the belting.
CARPE CRUSTULORUM!
08/31/2014 9:24 PM
EP 150 could be EXTREME PRESSURE and 150 the pressure rating ( units maybe psig?).
That I know of is conveying belting uses EPDM material ( Ethylene Propylene Di-ethyl Monomer ) . Please verify and could be EP may just be Ethylene Propylene as stated earlier.
08/31/2014 9:43 PM
Contact: Tiantai Dongfang Rubber Factory and ask then what it means, they make it.
Crabtree (1); Fredski (2); lyn (3); not so smart (1); Satish Menon (1); Tornado (1); Yahlasit (1)
