Previous in Forum: Enamel Heaters   Next in Forum: Material of Shaft
11 comments
Nitrogen Volume Calculation
09/03/2014 9:53 AM
Hi
I would like to know the nitrogen volume calculation
To pressurize 10 cubic meter of pipe line ,how much volume nitrogen required on the below condition ?
1. only to purge at positive pressure?
2. pressurize with 30psi ?
how much gallon of liquid nitrogen required fill 1 cubic meter at atm pressure?
how much gallon of liquid nitrogen required fill 1 cubic meter at 30psi pressure?
please share your stuff ..
Re: Nitrogen volume calculation
09/03/2014 10:16 AM
Please share your stuff first:
Gallons (undefined which gallon), psi, and cubic meters don't really go together. When you convert your units, what do you get?
09/04/2014 9:39 AM
Hi
Thanks for your reply
Pipe volume is in cubic meter
nitrogen volume is required in Us gallon
Pressure is psi
09/04/2014 9:44 AM
One cubic meter = 264.17 US gallons.
So ten cubic meter pipeline requires 2,641.7 US gallons of liquid nitrogen to fill. This is correct for 1 atmosphere and 30psi (both psig and psia).
As Crabtree stated, temperature may come into play here somewhere.
09/03/2014 10:44 AM
A1) It depends on the throughput and the purge pass condition, which aren't stated.
A2) 44.7/14.7 times as much as A1 above.
A3) it depends on final temperature, which you haven't stated either.
A4) 44.7/14.7 times as much as A3 above.
Good moaning!
09/03/2014 11:09 AM
What are you actually trying to do? Why do you want to purge this pipe and nothing else? What is the significance of 30psi? If it were either 40 or 25psi would it matter?
Good moaning!
09/03/2014 11:28 AM
"What are you actually trying to do?"
Get a passing grade on this class, I suspect.
09/03/2014 11:42 AM
Hahahahahahaha!
Good moaning!
09/04/2014 9:44 AM
Hi Crabtree
Requirement of purging/lay up for commissioing. Pressure does not matter . I would like to calculate the volume in gallon for final pressure.
i have note this formula
The nitrogen volume required to purge equipment with a simple cross
section is determined using the following formula:
V = VoP/14.7
Where:
V = Total nitrogen volume required (scf)
Vo = Water volume of pipeline (cf)
P = Absolute pressure of nitrogen in the pipeline
during purging (psia)
Is it right?
09/08/2014 5:36 AM
If the pressure <...doesn't matter...> and there is nothing to say about the point when the purge criterion has been met then the volume required is certainly no greater than the volume of the pipe.
If the temperature is undefined as well, then the volume of liquid nitrogen to achieve the undefined volume will also be no greater than the volume of the pipe.
And that is all that can be said about that sorry state of affairs.
Re: Nitrogen Volume Calculation
09/03/2014 1:34 PM
A. 10 cubic meters.
B. 15 cubic meters.
C. 20 cubic meters.
D. 1 gallon per PSI.
E. 2 gallons per PSI.
F. 3 gallons per PSI.
G. All of the above.
H. None of the above.
How to calculate gas volumes | The Chemistry Journey | The
Ideal Gas Law Equations Formulas Calculator Volume
Chemistry Tutorial : Molar Gas Volume - Aus-e-Tute
10/26/2014 1:20 PM
To calculate vol. of liquid N2 to fill 10 Cu. m of N2 at ambient temp. we proceed as follows:
22.4 M3 of any gas at NTP (1 atm. & 0 deg. C) weighs equal to its Mol. wt. in kg.
which means 10 M3 vol. of N2 at NTP weighs = (28/22.4)*10 = 12.5 kg
To calculate wt. at ambient (say 20 deg. C) the wt. will be less as per gas laws = 12.5*273/(273+20) = 11.65 kg
The density of liquid N2 = 0.807 = 0807 kg/litre
Vol. of liquid N2 required = 11.65/0.807 litres = 14.44 liters = 14.44/3.785 US gallons
= 3.815 US gallons
To calculate liquid N2 Vol. required at 30 psi proceed as follows:
Wt. of N2 at 30 psi as per gas laws = 11.65*30/14.3 = 24.44 kg = 24.44/0.807 = 30.28 litres = 30.28/3.785 US gallons = 8 gallons.
This could have been calculated directly as = 3.815*30/14.3 = 8.00 gallons.
Register to Reply 11 comments
Crabtree (3); Doorman (3); kasharma (1); lyn (1); Mohamed Shameer J (2); PWSlack (1)
