Previous in Forum: Joint Efficiency Of Pressure Vessel   Next in Forum: Is DownWard Air Flow Necessary For Lift?
60 Deg. Y-Valve
09/11/2014 6:46 PM
Is 60 deg Y-valve the other name for a strainer ?
Pathfinder Tags: pump strainer valve
Re: 60 deg Y-valve
09/11/2014 7:40 PM
No; it is basically a globe valve oriented at at angle to achieve less pressure drop.
Re: 60 deg Y-valve
09/12/2014 3:50 AM
A strainer is not a valve.
Re: 60 deg Y-valve
09/12/2014 4:55 AM
Thanks
Re: 60 Deg. Y-Valve
09/14/2014 9:32 AM
This is a Y type valve
This is a Y type strainer
Register to Reply 4 comments
cckla (1); MOBI (1); PWSlack (1); Tornado (1)
