Previous in Forum: Proface HMI PS4800 as PanAlarm   Next in Forum: Transmitter Yokogawa EJX430 Show IOP and Normal Again
13 comments
Can You Suggest Flowmeter for Corrosive Gas ?
09/12/2014 12:25 AM
Here the line size is 14 inches. Fluid is acid gas and velocity is high.
Operating pressure 60kpag
Max flow: 10367 Nm3/hr
Min flow: 4712 Nm3/hr
Mol. Wt 34.42 kg/kmol
operating temperature 40 deg C
We were earlier planning to use a 12" vortex flow meter for the same. But min. flow criteria is not being met easily.
our requirement is that we need a minimum drop across flowmeter and as it is the operating pressure is very low.
Ca there be any other cost effective solution for this other than vortex?
Re: Can you suggest flowmeter for corrosive gas ?
09/12/2014 3:33 AM
Of what material is the line constructed, please?
Good Answers: 94
09/12/2014 7:10 AM
Not my area of expertise but would an ultrasonic flowmeter work? No need for anything inside the pipeline.
Good Answers: 122
Re: Can You Suggest Flowmeter for Corrosive Gas ?
09/12/2014 3:55 PM
An orifice plate meter (D/P) with temperature compensation should work well.
If a review of the meter performance information from a reputable manufacturer is too confusing, a call to the technical support department is free and will solve which meter will work best in your application.
09/13/2014 1:57 AM
Please suggest Orifice Material of construction ( Moc )
09/15/2014 5:01 AM
The same material as is the pipe in which it is to be installed?
09/13/2014 8:00 AM
@ PWSlack - line is of SS316
@ Nigh - yes ultrasonic is a good solution and we also thought of that. but this gas is coming from battery limit and we are not sure if gas contains some particulate matter or not. So transit time ultrasonic may give erroneous reading if it is not clean.
@Shockhiscan - Actually we are not able to use orifice as pressure drop required is too small. we did consider venturi though, but its a very expensive solution.
Good Answers: 94
09/13/2014 4:17 PM
I thought that ultrasonic needed to have particulates or bubbles in order to have something to measure?
09/14/2014 3:43 AM
I think doppler type ultrasonic needs dirty liquid or gas bubbles to reflect from... but its for liquids only
The ultrasonic based on transit time needs fluid to be clean... but a colleague of mine recommended Emersons Multipath ultasonic flowmeter.
Good Answers: 176
09/14/2014 6:35 PM
The operating pressure of Operating pressure 60kpag is a little less than 9 psig.
I am unaware of any transit time ultrasonic clamp-on flow meter than can measure gas at that line pressure in metal pipe. I'd want to see it before I'd buy it.
Siemens has a good chance of measuring flow at that pressure in plastic pipe, but then there's the question on the use of plastic pipe.
09/14/2014 11:13 PM
@Iris - Though this was not a clamp-on type ultrasonic which we were planning to use. but yes you are right... the operating pressures are too low and therefore this solution will not be appropriate.
According to this operating pressure is 345-27,579 kPa
http://www2.emersonprocess.com/siteadmincenter/PM%20Daniel%20Documents/T-20-Series-Gas-USM-Transducers-Flyer.pdf
09/15/2014 7:00 AM
It depends on the <...plastic...> and it depends upon the <...acid...> in the gas, neither of which have been disclosed so far. Is there a Process Engineer at the facility who can advise?
Pitot tube and an inclined manometer would fit the spec at the moment. Check out the Dwyer catalogue (usual disclaimer).
09/16/2014 3:30 AM
Material of pipe is SS316
And fluid is acid gas (very high H2S concentation with presence of water vapor).
Pitot tube or annubar we are not preferring as we are not sure if the gas is dirty or not.The acid gas is coming in from battery limit. Process engineer is not sure if gas may have some particulates.
yes, we are in talks with some vendors to provide an ultrasonic solution for such low operating pressures if possible.
India - Member - ADIL MOULA Engineering Fields - Instrumentation Engineering - Adil Moula
09/15/2014 10:51 PM
Flexim G801 , noncontact type uitra sonic meter.should be a better solution
http://www.flexim.com/en/fluxus-g801
baishakhi (4); find2am (1); Iris (1); Nigh (2); PWSlack (3); SHOCKHISCAN (1); vivek bajpai (1)
