Previous in Forum: Leaking Hot Melt Gun   Next in Forum: papers
Sprinkler head
07/04/2007 12:53 AM
I want to have specification on sprinkler head devices, and how to recognize if it is to the recommended standard.
Re: Sprinkler head
07/04/2007 6:50 AM
British Standards are applicable to Britain. So, what country does this post apply to, please?
Re: Sprinkler head
07/05/2007 12:13 AM
Manufacturers put out spec sheets on eack type of sprinkler and their application and installation guidelines.
Otherwise refer to NFPA 13 for installation guidelines for fire sprinklers.
Re: Sprinkler head
07/05/2007 3:46 AM
Just read what is written on the deflector.
Compare this data with what should be installed.
All sprinkler companies have the data sheets on their websites, it should be easy to find the exact data of what is installed.
The glass bulb is color coded for the opening temperature. Be carefull with this info: where direct sun can touch the sprinkler head the standard red bulbs are not applicable (68°C)
Re: Sprinkler head
07/05/2007 5:40 AM
You would first want to check the NFPA for your standard as they are the guide for for Federal standards.
Good Answers: 16
Re: Sprinkler head
07/20/2007 12:07 AM
Wherefore art thou Patjustine?
The required standard varies from one country to another and it is important to use the local legally defendable standard. Even if the standard that you install exceeds the locally required level you are wide open to litigation from lawyers and criticism from the accountants.
Make it so.
Anonymous Poster (1); BigEd (1); BlueAussieBoy (1); Gwen.Stouthuysen (1); PWSlack (1)
You might be interested in: Captive Screws, Nails, Lockbolts
