We have a receiving substation (220kv/33kv/11kv,3-winding) which feeds power to one 1.6MVA (11kv/0.433kv ,Dy) through 11kv cable (85m) to a plant load centre. The plant load centre equipment earthing has been provided with a number of earth rods driven into the ground arround the plant building and connected together. The load center transformer neutral is grounded separately. In this configuration , do we need to calculate Step & Touch potentials at the plant (as the source 11kv is local ) and if yes , how I will use IEEE 80 to calculate Earth grid resistance (Rg) as it is not a grid rather a hollow square.
