Previous in Forum: Trapezoidal Rule Approximation   Next in Forum: Is 3 Phase Line Always Balanced?
8 comments
Electric Arc Furnace Regulation
09/24/2014 2:58 AM
Hi.. I'm a newbie in here..
I want to ask about electrode regulation in Electric Arc Furnace, as i know EAF regulation were determined by it's impedance (Z).
My problem is I recently change my conducting arm into the new model (different from the past), and I want to operated the furnace again, what I think is that the new conducting arm will have a different impedance (Z) than the old one. I want to recalibrate the electrode regulation to adopt the new system. Can you please tell me how to do the calibration?
I have no clue at all
Re: Electric Arc Furnace Regulation
09/24/2014 9:45 AM
Write, e-mail or call the maker of the furnace and ask for the calibration instructions.
Or, just turn it on and see what happens.
09/24/2014 1:26 PM
Or, just turn it on, STAND BACK and see what happens.
You have to actively participate in the manifestations of your own joys and good fortunes - they are not ready made for the taking, they are available for the making.
Good Answers: 181
09/24/2014 8:38 PM
Getting someone else to turn it on is much safer.
09/25/2014 9:12 AM
I will trade you an apple . . .
Good Answers: 181
09/25/2014 7:28 PM
No thanks, I know what happened last time an apple was offered.
Good Answers: 97
09/24/2014 3:18 PM
Upon start-up, the electrode will run in to strike and retract to a balanced point. There has to be a fine adjustment to trim for optimum arc. You may also have to adjust the anticipator.
CRTL-Z
Good Answers: 21
09/24/2014 10:36 PM
I think Lyn has your best choice so far. Yo do not say if it is an AC or DC unit or the type of regulator your using. There are many companies that provide these services for folks such as your self. It also is some thing you should not be doing unless you know what your doing. You can do a lot of damage to the equipment in a big hurry. Read Gary Bakers book on Furnace regulation, good info!
Fixit
10/06/2014 9:52 PM
Thanks for all of your answer,
@fixitorelse : I'm sorry I didn't describe the detail about the furnace, it's an AC furnace feed of from 60/66MVA transformer with Voltage Rating : 30kV/490-850Volt and Current : 1307-1800/63500-80000A. I'm interested in your suggestion to read "Gary Bakers book on Furnace regulation", but I can't find the book. Can you please tell me more detail about the book? Like the title and the publisher, a link if possible. Thanks.
@all : I'm just curious I have been reading some article and one of the article said that the good Z in transformer secondary (Line power to furnace) is the same as the Ztransformer. Than I remember about maximum transfer power that will happen when the Zin = Zout, where in this discussion. Zin = Ztransformer and Zout = Zactual = Zset.
And what I was thinking is that, the transformer I used is still the same an has no change, so having the transformer secondary (Line power to furnace) change (ex. The conducting arm), really does't effect in the change of Zset because you want to set the Zset to be same as Ztransformer.
How about your though? Sorry for my bad english >Z<
Register to Reply 8 comments
fixitorelse (1); hino (1); lyn (1); Mike W (2); TonyS (2); Unredundant (1)
