Previous in Forum: Electric Resistance Single Phase Heating Element   Next in Forum: Determination of Fiber Tension for Winding Carbon Fiber by Filament Winding
How to Dismantle Cam Follower Lever Assembly
09/28/2014 5:47 AM
I'm working on Reman and reconditioning of Cam follower lever.But when goes to dismantle the lever,then ?
Questions:
i) How to dismantle Pin cam follower from Lever without press.If it will dismantle with press, found damaged.( scratches,dents) ?
ii) How to dismantle the socket from whole assembly ?Socket has small hole at center and from opposite side roller assembly ?
This 1 specifically for Diesel engine cam follower lever.
Is there any process By using this we will Reman it ?
Re: How to dismantle Cam follower Lever assembly?
09/28/2014 5:54 AM
09/28/2014 8:51 AM
When in doubt, C4.
09/28/2014 9:13 AM
Nobody said it had to go back together again.
09/28/2014 7:13 PM
Progressively larger hammers.
09/28/2014 7:18 PM
E.g., Maxwell, John Henry, Thor, Malleus Maleficarum.
Re: How to Dismantle Cam Follower Lever Assembly
10/03/2014 3:21 AM
Employ a hollow carbon rod to carry a electrical charge. Use such rod slightly smaller than pin diameter and feed coolant through hollow rod manage minimal feed of rod in contact with pin. After hollow rod has passed through arm remaining sleeve of pin material may be removed, without damage to arm but necessitates replacing pin.
Register to Reply 6 comments
Anonymous Poster (1); jdsighter (1); lyn (1); redfred (2); Tornado (1)
