Previous in Forum: Shunt Resistors For AC Current Measurement   Next in Forum: NEC Split Air Conditioner
How To Restore The Residual Magnetism In My DG?
09/29/2014 3:19 AM
500 KVA DG, kept idle for last one year, now i am trying to start the DG it was generating only 40v instead of 440v AC so now i feed the 12v dc from battery for excitation (externally) now this moment i can get 460v at output terminal. once again i am connecting through AVR (E+ AND E-). The situation remain same (means still it was generation 40v) now one thing is very clear that is the residual magnetism of the field may lost due to laid idle. if it is so kindly suggest me how to restore the residual magnetism? or any other issue please suggest how to solve this issue?
Good Answers: 445
Re: How To Restore The Residual Magnetism In My DG?
09/29/2014 8:48 AM
It means that something between the terminals of the machine and the terminals for the field is open. If you have 40 Volts without external excitation and 460 V when you flash the field then you have enough residual magnetism to build up voltage IF everything else is working properly. Check fuses, diodes, AVR, connections, etc. until you correct the problem.
09/29/2014 8:49 AM
Good Answers: 97
09/29/2014 10:51 AM
If your generator has circuit boards, rodents can do some serious damage to them.
Check for mouse peepee tracks.
CRTL-Z
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Technical Writing - New Member
09/30/2014 12:04 AM
In the alternators the Residual Magnetism is stored in Exciter Stator Laminations, all other parts like Main Stator and Main Rotor are of Silicon Grade Material do not store residual magnetism.
If the terminal voltage is 40 volts, the AVR should pick up and the Alternator should build up the voltage. In case of Cummins, LS and Weg alternators the Min Residual voltage required for voltage build up varies between 3 to 9 Volts only. Please try changing the AVR
If Changing AVR does not work, try following, after every step check the voltage build up -
1. Do not run the engine and Flash the Exciter Stator terminals with 12 V DC with the help of External DC Source (Battery Bank) ( E+ Positive and E- Negative)
2. If voltage is not building up, then increase the Excitation Voltage in the steps of 12 Volts till 36 Volts----- Do not Run the engine....This is static Charging of the Excitator Stator.
3. If the above 2 Fails to charge the Excitator Stator.. Remove the Excitator Stator..charge with 40 V AC ( Yes AC)...then charge with 36 Volt DC.
4. The final solution would be to replace the Excitator Stator.
09/30/2014 4:48 PM
If you have 40v terminal voltage, you have residual voltage. If the unit is shunt excited. (AVR is powered by the output terminals of the generator) the AVR is bad and needs replacement. If the AVR is powered by a PMG. Check the input voltage to the regulator. If it has the correct voltage, AVR is bad and needs replacement. If it does not have voltage going to the regulator, replace the PMG.
CBlackwood (1); RAMConsult (1); SolarEagle (1); Unredundant (1); vishram lele (1)
