Previous in Forum: Elcb Tripping   Next in Forum: High Voltage Cable Laying
8 comments
HV Motor
10/03/2014 7:58 PM
Can anyone give me a chart for calculating the amount of round copper Coil in Kilogram that can goes into rewinding of 1250kva Stamford stator AC alternator , other data are 3300V,50Hz,219A,3ph,Speed 1500rpm and other lesser alternator .
Pathfinder Tags: Rewinding AC motor
Re: HV Motor
10/03/2014 10:13 PM
This is an odd request that makes me ask, why do you want to know?
Are you looking for how much copper can be recycled from one of these machines? I legitimate recycler would not care how much copper is in there, they would just pay a standard price based on the weight.
A legitimate alternator rebuilder would need to know also the gauge and required insulation to rebuild.
Re: HV Motor
10/03/2014 10:51 PM
Will one of these work?
Re: HV Motor
10/04/2014 5:36 AM
Contact motor rewinding company
pnaban
Re: HV Motor
10/04/2014 12:11 PM
I'd ring the manufacturer, then I'm funny that way.
Good moaning!
Good Answers: 128
Re: HV Motor
10/04/2014 11:00 PM
Cyclo,
1. No
2. I strongly suspect that it is form-wound, which is with copper that has a rectangular cross-section. "Round copper coil" not applicable.
JMM
Good Answers: 27
Re: HV Motor
10/05/2014 8:47 AM
The round copper wire area is measured in circular mils, (CM) and the weight of of a bare copper wire with 1000 CM is approximately 3 pounds per 1000 feet.
If you are planning to sell the burnt wires, the price per pound varies depending on your location, quality and quantity of your wire!
It seems you do not have the necessary know-how needed basing from your question, that if you are planning to rewind or rebuild the motor, you may fail! The motor may not run, over heat causing the new copper wires to be burned again and may even cause fire!...
vsar
Re: HV Motor
10/06/2014 11:49 AM
From my work experience it is approximately 1 kilogram of copper coil for each kW. To find out the exact amount contact the manufacturer.
Re: HV Motor
11/11/2014 2:07 AM
If you entrust the work to a rewinder he will do it .Normally they see the damaged coils and manage it
Register to Reply 8 comments
Crabtree (1); Dosa Ion (1); jmueller (1); lyn (1); nesubra (1); pnaban (1); redfred (1); vsar (1)
