Previous in Forum: Unsiffened Dome Roof   Next in Forum: Boiler Drum Water pH and Boiler Feed Water pH
India - Member - New Member
Hydraulics
10/16/2014 12:26 PM
Hi,
I am using variable displacement piston pump in my hydraulic station.pump has pressure compensatory adjustment and in delivery line relief valve is available. My doubt is which pressure setting should be more, either pump ccompensation or relief Valve.
Nithin
When Emotions runs high ,Intellectual wont work
Re: Hydraulics
10/16/2014 4:23 PM
Set the compensation at the desired pump pressure and the relief valve at the value you want it to open.
If you set pump compensation higher than relief valve setting, you will not be happy.
Good Answers: 266
Re: Hydraulics
10/17/2014 8:04 AM
The pressure compensatory valve should be set to a pressure no higher the the maximum pressure rating on the devices it's controlling. Just because the cylinder it regulating pressure to can handle 3000 lbs does not mean the the device structure can. See the manual or call the manufacture for those specs. In load bearing equipment adjust it to lift the maximum load listed for the equipment with test weight.
The relief valve can be set to the maximum rated pressure of the hydraulic unit. Specs on that would also be in the manual, stamped on the ID plate or call the manufacture.
In practice the relief valve to save energy should be set 10% higher then compensatory valve. Not to go over the hydraulic unit max pressure rating.
Register to Reply 2 comments
