Previous in Forum: VSD Allen Bradley 753   Next in Forum: Earth Fault in Parallel Operating Gensets
22 comments
Running of a 500V Compressor Motor On 400V
10/30/2014 5:10 AM
Dear Friends;
We have a screw air compressor Atlas Copco GA808 which has a 75KW 500V motor runs on star delta. As we have 400V power supply system, so initially we want to run this compressor on 400V to test it with load. So what will happen with motor when we run it on 400V? Obliviously its torque will be reduced but for how much percentage?
Good Answers: 69
Re: Running of a 500V Compressor Motor On 400V
10/30/2014 8:41 AM
Your real concern shouldn't be the torque drop, but the motor overheat.
10/30/2014 8:45 AM
its going to cook the motor, stop being an idiot and install the proper t-former
Good Answers: 104
10/30/2014 9:12 AM
How about the frequency? What do you have? What is the motor designed for?
Good Answers: 804
10/30/2014 10:49 AM
500VAC is not a standard for anywhere in the world. My first inclination is that you do not have your facts straight. Either that, or Atlas Copco is doing something very odd with regard to playing with the Volts /Hertz ratio of the motor, but you did not post the frequency data on the motor nameplate.
Option 2, you are ASSuming the motor voltage by reading the voltage rating of a VFD that is controlling the motor. VFDs come in different "classes" of voltage ratings, and some mfrs, such as ABB whom Atlas Copco like to use, use "500V class" as a way to separate drives that are rated for 380-480V input as separate from 400V class, rated from 380-440V input. That would not really apply to the motor, but if you are reading the VFD nameplate and not the actual motor, you might be fine, but you also might need to adjust programming in the VFD.
Option 3, slightly less plausible, is that for whatever reason, this was built with a 500V DC motor. 500VDC much more common in the DC world, but DC motors are uncommon on compressors because of the high duty cycle and required maintenance.
Go back and read the ENTIRE motor nameplate, then maybe we can help.
Good Answers: 181
10/30/2014 11:36 AM
500V is used in mines and quarries
10/30/2014 12:50 PM
I'm trying to get my head around a star-delta DC motor, to say nothing of the OP's motor.
10/31/2014 7:25 AM
Puzzeled too. A DC motor on the compressor! All the ones I have checked out ar 400V AC motors. Is this some special application or a home work question or a misread spec plate?
10/31/2014 1:31 PM
Dear Mr.JRaef,
It is true that 500 Volts is not standard, but one company formed about 200 years back in London, still ha s branch and working in India, it is using still 500 Volts.
DHAYANANDHAN.S
Good Answers: 97
10/30/2014 3:55 PM
When you start upon a star, makes no difference where you are, if your voltage is too low, the smoke comes out.
Jiminy Cricket.
CRTL-Z
Good Answers: 804
10/30/2014 4:12 PM
  • I'm trying to get my head around a star-delta DC motor, to say nothing of the OP's motor.
D'oh! <slaps forehead>
Missed the "star-delta" thing. Damn these eyes...
10/30/2014 4:29 PM
This sounds like the rating in star mode, the delta mode probably 380v....we need complete info off starter and motor....
Good Answers: 804
10/30/2014 6:13 PM
Nah, 380 x 1.732 = 660V. There are 690Y400V motors out there for that purpose. But nothing about 500VAC works out mathematically with any world standard for AC distribution voltages.
But here is something that does sort of work out, based on my earlier comment about Atlas Copco "playing with V/Hz ratios".
A motor designed for 415V 50Hz (not 400V or 380V) will have a V/Hz ratio of 8.3:1. if you want full torque from that motor at 60Hz, you would need to supply that motor with 8.3 x 60 = 498V, pretty damned close to 500V. So IF the motor nameplate truly says "500VAC 60Hz" on it, then it will be fine for 415V 50Hz, and if tolerance is +- 10%, 400V 50Hz should be OK as long as the supply does not dip lower than 373V, about 6-1/2%.
10/30/2014 8:50 PM
Indeed while 400 V 50 Hz and, for some larger more recent drives, 690 V 50 Hz, are the most common 3-phase low voltages in continental Europe, 500 V 50 Hz 3-phase is still used in some large industrial plants (e.g. cement and chemical plants). As they can't replace thousands of motors easily, there's now typically a mix of 500 V 50 Hz and more recent 400 V 50 Hz as well as in some cases 690 V 50 Hz in the same plant. In some countries the same plugs can be either 400 V or 500 V (mostly legacy connector systems). 500 V 50 Hz is phased out where possible but will likely coexist with 400 V 50 Hz for quite some time.
10/30/2014 9:48 PM
We had an old paper making machine got from Germany. The voltage of this machine was 500V 50HZ and so the compressor is also of 500V 50HZ and has a star delta starter. The machine has become right-off and the compressor is spare. Designing a step up transformer from 400 to 500V is a secondary concern.
Every time comments by Tornado are very nice.
Good Answers: 181
10/30/2014 11:41 PM
When I started quarries 40+ years ago all our plants were on 525V. Later as new kit came in the plants ran with a mixture of 525V and 433V.
We did toy with the idea of converting them to all 433V, we gave that idea up as an expensive pipe dream. The shear cost of 1500 new motors never mind the new larger cabling consigned the idea to the bin.
I was involved in the first dual voltage system so it became 2nd nature knowing what was on each voltage.
The OP mentioned that this motor was from a printing plant. The last printing plant I worked on again had two systems. This time 433V and 380V. The plant services being to UK specifications, the presses to Belgian and German.
The foundry I worked at used 660V and 433V.
It's not all that unusual in old industries for dual voltages to exist side by side. It's just a bit mind blowing when you first come across it.
Good Answers: 22
10/31/2014 4:26 AM
500V motor working at 400V (80% of 500V) will be able to give ~64% torque.
If this is good enough for the compressor, I don't think the motor will have any problem.
Raghunath
10/31/2014 6:40 AM
The 'load' is caused by the compressor screw element. This relates directly to the speed and pressure. The motor is matched to deliver the power at full load.
Running at 400 volts will reduce the power to 64% of 75kw = 48kw (it's to do with V2). The motor will therefore become overloaded when trying to deliver little more than half the rated airflow.
The screw element needs to run at half speed to avoid overload, or at half rated pressure.
The latter easy to achieve by setting the max pressure controls, but not very useful because you probably need the full air pressure for your pneumatic machines to work properly.
Halving the speed of the screw by changing pulley wheels would be somewhat easier if belt driving, but your compressor is probable direct coupled through a gearbox, making it impossible.
If you do not reduce the screw speed or pressure, then the motor will try to match the air consumption, and anything much over half load will cause the motor to 'slow down' pulling more current than designed, and soon to overheat.
For testing purposes, ie, running up to speed and pressure, should present no problems, but as soon as air is consumed, over which you have little control (I guess) then things will start to go wrong if unattended.
10/31/2014 10:47 AM
If you Google the "Atlas Copco GA808" you will find several descriptions rating it at 400v.
10/31/2014 1:38 PM
Dear Mr.signode,
The motor will draw more current and windings will get over heated. The power at 400 V will be (400/500)^2, to that of power at 500 V, and hence (400/500)^2 = (0.8)^2 = 0.64 and hence the current drawn will be 1/(0.64) = 1.5 Times more and there fore winding will get over heated/burnt.
DHAYANANDHAN.S
10/31/2014 2:10 PM
Obviously ignored by many so I shall point this out. How on earth can he test this compressor on load, and obtain meaningful results of any use if the the required voltage is 500V? Torque reduction or not, his test is totally without foundation and any result, has no value.
Good Answers: 42
11/01/2014 10:47 AM
It is an old compressor. See:
http://www.machinerypark.com/stationary-compressor-atlas-copco-ga-808-used-be-8790
It seems to me the rated voltage is 400 V [it is not 500V!] 50 Hz.
It could be your network rated is 480 V 60 Hz. Then it may work fine.
Julius
11/10/2014 1:22 AM
Dear Signode, Can we request for the nameplate photograph...
He must be very ignorant as he answers all the questions he is asked. Voltaire
Register to Reply 22 comments
7anoter4 (1); bigg (1); chaterpilar (1); dhayanandhan (2); Fredski (1); horace40 (1); IQ (2); JRaef (3); Plimos (1); raghun (1); Signode (1); SolarEagle (1); tommm (1); TonyS (2); Tornado (1); Unredundant (1); Yahlasit (1)
