Previous in Forum: Reverse Mounted Vibration Probes   Next in Forum: Thermistor Bridge Linearisation
Pneumatica Temperature Transmiter Calibration
11/10/2014 3:14 AM
Hi,
Do any of you know of a temperature calibrator for negative temperatures.
We have a temperature (1 to -30º C) to 3-15 psi transmiter that I need to calibrate.
Regards
Good Answers: 109
Re: Pneumatica temperature transmiter calibration
11/10/2014 4:00 AM
Calibration is the same isnt it?
Is just the range that is different.
If in doubt ask the manufacturer.
Some literature that might help:
web.mst.edu/~cottrell/ME240/Resources/Temperature/Temperature.pdf
ww1.microchip.com/downloads/en/DeviceDoc/21895d.pdf
Good Answers: 11
11/10/2014 4:04 AM
You may look for an AMETEK calibrator they have products on this ranging -90 deg C to 700 deg C also for pressure calibrator.
11/10/2014 2:55 PM
Thanks... this ametek calibrator is exactly what Im looking for... thanks a million
Good Answers: 176
Re: Pneumatica Temperature Transmiter Calibration
11/10/2014 7:41 AM
The Ametek (or any other brand) dry block calibrator that covers a negative temperature range (thanks to Pelletier thermoelectric cooling elements) will provide a traceable temperature source to cool or heat the transmitter's sensing bulb to a specific temperature, but it won't 'calibrate' the pneumatic 3-15 psi output of the transmitter. So, you'll also need a traceable reference pressure indicator like a mechanical test gauge or an electronic pressure calibrator. Wallace and Tiernan's "Wally box" is still used for field grade pressure calibration (now sold under the Wika brand), but any traceable gauge would do the job.
Good Answers: 203
11/11/2014 11:05 PM
cooling agent /// organic solvent /// temp
ice /// water /// 0oC
dry ice /// o-Xylene /// -29oC
http://en.wikipedia.org/wiki/List_of_cooling_baths
Good Luck, Old Salt
IdeaSmith (1); Iris (1); Noudge79 (1); old salt (1); porky2009 (1)
