Previous in Forum: Short Circuit Ratings of Control Panels   Next in Forum: Electrical Maintenance Help
Contact multiplying of CTPT unit-33kv
11/24/2014 1:38 AM
Dear all Experts,
please guide me how to multiplying terminals of existing CTPT unit in the 33 KV line that is already connected to breaker unit. i need to use the same contact for metering purpose and to breaker simultaneously using some option such as Contact Multiplier Relay(My assumption) . can any body experts in these logic please help me.
Rahul
Re: Contact multiplying of CTPT unit-33kv
11/24/2014 2:52 AM
http://www.sepl.in/ct-pt-metering-set.html
You better look for a consultant that has experience with this.
11/24/2014 3:21 AM
Well, I would start by getting on the phone to the original equipment supplier and start there. Then, I'm funny that way.
Good moaning!
11/24/2014 4:43 AM
Don't forget your thick rubber gloves and tin foil hat.
Get an expert to do this and keep far away.
Good Answers: 122
11/24/2014 10:30 AM
I would check the existing breaker unit and identify what the CTPT output analog circuit reports to (is connected to).
Is it connected to a digital or analog protection relay or just a direct reading meter?
If it is connected to a digital relay: Is there an auxiliary relay output available on the relay?
If it is connected to a direct reading analog meter: The analog metering loop can be series with other metering equipment.
DANGER!
All power sources must be isolated from the CTPT and the output circuit terminals shorted before accessing and/or working on the circuit.
Failure to do so will result in extreme damage to equipment and or personnel.
This work requires circuit interrogation and design by a competent individual knowledgeable of electrical metering applications and theory.
11/25/2014 1:05 AM
Dear shockhi,Thanks a lot for your valuable replay.
Actually CTPT unit is connected to Siemens Breaker tripping unit.let me check for any Aux contacts.
Rahul
Crabtree (1); IdeaSmith (1); lyn (1); rahulgrove (1); SHOCKHISCAN (1)
