Previous in Forum: Checking Over or Under Spray of Glaze on Ceramic Sanitaryware   Next in Forum: WaterJet Cutting Supplier
11 comments
Round Wire Flattening
11/29/2014 1:15 AM
i need to know theory or formula of wire flattening to square or rectangular flat shape from round shape , process is two pinch rollers of 6'' dia , gear box driven ..
example 4mm round wire , flattened to 6mmx 2mm strip form
so the upper roller should be pressurized 2mm downward from neutral position . ?
shamsher singh (mech engineer manufacturers)
Re: round wire flattening
11/29/2014 1:33 AM
I don't think you can do it with just a single pass through pinch rollers.
The edges won't be flat.
Best to buy flat wire to start with.
11/29/2014 1:56 AM
may it be 3 or 4 station passes , my question is for what is theory for calculation , of what size round will form what size flat . example if i want 3mmx 2mm flat what size round i have to input .
thanks for your comment ..
Good Answers: 11
11/29/2014 11:16 AM
i bet you need to study geometry, regarding cross sectional area and perimeter.
11/29/2014 2:12 AM
It will depend on how much stretching occurs as the wire passes through any rollers or dies. The resulting cross-sectional area will be somewhat less than that of the original wire. Your example would be 12.57 input area and 12.00 output; I suspect that the real reduction (and stretching) would be more.
11/29/2014 10:01 AM
I suspect that this is never calculated but empirically discovered. To calculate from theory would require knowing the temperature of the wire, the wire alloy and consistency, the roller surface and alignment quality and probably a few other attributes I have not considered.
11/29/2014 10:08 AM
I agree.
Machine the desired rectangular groove configuration into one roll and leave the top roll smooth.
Then experiment with wire sizes. Depending on the wire composition you may have to run a larger size wire through sizing dies to get it right.
11/29/2014 11:21 PM
The volume of the wire must remain constant. So if the length increases by 20% during the flattening process (i.e., the final length is 1.2x the original length, the cross-sectional area will be 83.33% of what it had been prior to flattening. (cross sectional area x length = volume)
There are 10 kinds of people in the world.... Those who use binary code, and those who don't.
11/29/2014 11:48 PM
Why must the volume remain constant? I believe that there will constantly be little flakes of wire cracking off, along with oxides falling off all the time. Not to mention breakages and fraying that can also happen. It all depends on the metal that makes the wire. Gold will be closest to your ideal volume proposal. Copper and Silver will probably work similarly. The oxidation of Aluminum will pose a different set of problems. Nitinol will be a completely different challenge. Did I ever mention adhesion as a possible problem, I don't think that I did.
11/29/2014 11:57 PM
Well, if you can determine the losses due to flakes, etc., subtract that first.
I guess I was just trying to give a starting point for the calculation: If the volume of the wire remains essentially constant and you know the change in the length, you can easily calculate the new cross sectional area.
11/30/2014 12:09 AM
But, does that tell you where the rolls must be in relation to each other to get the cross section desired? I think not.
You can calculate till next week, but running wire will be the only way to determine the proper roll spacing.
And a single pair of rolls to go from round to square is a joke.
This should be directed toward the OP, but without something to calculate, it'd be lost on them.
<edit> Ga to GW
Good Answers: 42
11/30/2014 12:00 AM
Quite a few years ago I worked on an automatic gauge rolling machine, and also on wire drawing machines.
1) the mass flow through the sections remains equal. As area changes speed also changes.
2) the amount of "indentation" is also dependent on the stretch of the rolling machine, and the varying hardness off the incoming material.
3) pulling it through the dies versus having driven rollers will also effect the quality and reduction.
4) smaller diameter work rolls will significantly reduce the forces involved.
5) calculate the "ideal" dimensions. Then allow for some more "screw down" to accommodate frame stretch and plastic deformation you cannot readily calculate - there always is some trial and error.
Personally I think I would start with driven rolls or die sets for the forming.
Register to Reply 11 comments
GW (1); lyn (3); metal master engg (1); Noudge79 (1); redfred (2); Tornado (1); tribefan1952 (2)
