Previous in Forum: Oil/Tar Removal   Next in Forum: Drilling in Welding Line
11 comments
Hydraulics Proportional Valve
12/01/2014 8:10 AM
If pressure of 80bar oil- vg68 supplied to proportional valve of 80lpm capacity, is the pressure drop remains same as for 315 bar i.e 20bar or it will be different?.
Please do not relate or assume load sensor..or some thing else. Just consider there are no load sensors, it is only fixed 80 bar oil supply to proportional valve. Would the pressure drop remains same for 315 bar for which the valve is tested.
Re: Hydraulics Proportional Valve
12/01/2014 8:34 AM
I don't think so. The greater pressure should result in greater flow through the valve, thereby increasing the pressure drop.
Good Answers: 34
12/01/2014 9:51 AM
differential equation Bernoulli?
Good Answers: 266
12/01/2014 10:23 AM
The capacity rating is usually at the working pressure rating. Test pressure is usually 3 to 4 times working pressure. Pressure drop has to due with porting and fluid flow. Which would change with the application(the load on the driven device).
If I have only a fixed 80 bar oil supply. Then how do you put 315 bar on it!
12/01/2014 12:29 PM
It will be different. For detailed information on the valve's performance, please contact the local distributor directly.
Good Answers: 70
12/01/2014 8:43 PM
Your question makes little sense, your talking about a proportioning valve, so your pressure drop is going to be proportional to the valve position.
12/01/2014 10:40 PM
Little sense?
"Please do not relate or assume load sensor..or some thing else."
That means no sense.
12/02/2014 12:06 AM
I mean, when pressure required at end point is less there will be no sensor to initiate the system to supply higher pressure of oil to pressure port of proportional valve. It just fixed pressure 80 bar supply to pressure port of proportional valve.
Now I hope you got it!
Reply Score 2 for Off Topic
12/02/2014 3:09 AM
Not yet.
Good moaning!
12/02/2014 3:17 AM
If the supply is 315 bar and the downstream pressure is fixed, if the valve position is different then where does the remaining pressure drop go to sustain the same flow rate?
Good moaning!
12/02/2014 7:05 AM
315bar is the tested pressure for proportional valve by manufacturer. But it is used input pressure of 80bar which is fixed.
The pressure out put from proportional valve is used to operate in closing the component the system.
my question is if this 80 bar is used will have the pressure drop of 20bar, which is same as for 315bar (tested pressure) of proportional valve.
Good Answers: 70
12/02/2014 10:32 PM
This reply is for Anon #1, being none of us are there with you and can not see how you have this thing plumbed, why don't you simply put a pressure gauge down stream of your proportional valve, operate this system and see for yourself what the actual pressure drops are for the valve or what ever your going to operate, motors, rams or what ever
Oh yeah, how did you did come with a handle of "hydraulic14" and yet ask a question like in your OP?
Just wonder'n
Anonymous Poster (1); Crabtree (2); dj95401 (2); hydraulic14 (1); lyn (1); ozzb (1); PWSlack (1); Tornado (1); Whitephone (1)
