Previous in Forum: Hex Head Horizontal Pipe Cladding Machine   Next in Forum: How to Correlate The Average Nusselt Number
41 comments
Staircase
12/06/2014 2:47 AM
i have tank of 15m circum and 15m hieght. how i complete staircase for this tank within 270deg angle with 1 platform.
Good Answers: 70
Re: staircase
12/06/2014 3:01 AM
Contact a local engineer where this tank is located. We usually like to get paid for our designs.
Re: staircase
12/06/2014 3:53 AM
Start at the bottom and work your way up.
Re: staircase
12/06/2014 4:29 AM
Consult your local safety standards for requirements as to step size (width, depth, rise, tread, overlap, angle of rise) and maximum height between platforms.
Because of the 270deg restriction, you have only 11.25m horizontally to work with, which will reduce to about 10.25m because of the platform. This makes your rise/tread proportion equal to 15/10.25, which may be steeper (55.7deg) than locally allowable.
Maybe you can consider an alternating-tread design, if permissible.
Re: staircase
12/06/2014 9:07 AM
Good analytical response. I this the op hosed up on the diameter units thou.
Good Answers: 137
Re: staircase
12/06/2014 9:44 AM
I don't understand your 2nd sentence. Can you translate?
Re: staircase
12/06/2014 10:01 AM
I hosed up on that too... :-)
Replace 'this' with 'think'
Re: staircase
12/06/2014 3:12 PM
As per my detailed calculation, the angle is
55.68213107 Degree
Re: staircase
12/06/2014 3:26 PM
Your calculations does not have details, it's just numbers. If it had details it would at least have units.
Good Answers: 137
Re: staircase
12/06/2014 6:11 AM
That would be a tall thin tank, though of course not impossibly so. Tanks are usually made to a specified dia, not circum. Not 15m dia by any chance?
Good Answers: 34
Re: staircase
12/06/2014 7:22 AM
API 650, 620 and 653 are silent about staircase. But you can get information in
OSHA Doc. 3124-12R 2003
"Working on and around stairways and ladders is hazardous. Stairways and ladders are major sources of injuries and fatalities among construction workers for example, and many of the injuries are serious enough to require time off the job. OSHA rules apply to all stairways and ladders used in construction, alteration, repair, painting, decorating and demolition of worksites covered by OSHA's construction safety and health standards".
WP
Re: staircase
12/06/2014 7:28 AM
That's a good example of tackling bona fide design issues with pure drivel. So like a bureaucracy.
Good Answers: 34
Re: staircase
12/06/2014 7:37 AM
JeJe you're so funny. You have something to share?
Re: staircase
12/06/2014 7:43 AM
See post 3, which actually gives valid information. Then shut up.
Good Answers: 34
Re: staircase
12/06/2014 8:32 AM
I get bored, maybe a coffee and watch something on TV........
WP
Re: Staircase
12/06/2014 10:04 AM
Detailed Calculation
15000150002388.53503227011250380.6628888890.780744307100010250304.8237.9708646
Re: Staircase
12/06/2014 10:26 AM
What?
Good Answers: 137
Re: Staircase
12/06/2014 11:14 AM
He's having a laugh IMHO
Re: Staircase
12/06/2014 3:10 PM
Who is having laugh? I prepared one excel sheet based on this question.And Just changed couple of values, and posted it for peer review.Got one off-topic rating.Genuine spare part is still in my hard disk and the mathematiks used to solve this issue is very simple.
Re: Staircase
12/06/2014 3:25 PM
Sanweld, add some more information as to what these numbers mean. We don't read minds
Good Answers: 137
Re: Staircase
12/07/2014 5:32 AM
OK but from the information in #13 there's no way we can tell what your calculating. Also a lot of spurious accuracy! But on a more general point, as often happens we've heard no more from the OP, although several posters have tried to help. I wouldn't mind an answer to basic query in #4.
Re: Staircase
12/06/2014 2:39 PM
one off-topic rating. Looks like corrupted file.
Re: Staircase
12/06/2014 3:03 PM
Or coordinates to something spectacular
Re: Staircase
12/06/2014 4:24 PM
Are the stairs on the inside or the outside of the alleged tank? Do they start at the top or the bottom?
Why would you come to the forum and ask a question with no basis in reality?
Hopefully it is just homework, and you have no real position in the construction of such stairs!
Google "homework help".
Good Answers: 114
Re: Staircase
12/06/2014 7:39 PM
You reverse direction at the platform at approximately half way up. Say the top flight is attached to the tank and the bottom flight is free standing with its inside diameter slightly greater than the outside of the upper flight. It would look like two staircases on plan, one connected to the tank and the other outside of it.
Re: Staircase
12/07/2014 7:29 AM
Hire a journeyman welder or carpenter...the magic number might be near 17 if you do your calculations in inches, it depends on how comfortable you want to be when ascending or descending...or you might want to turn part of it into a "ladder".
Re: Staircase
12/08/2014 12:58 AM
This is a very old post I have only just joint the site so I don't know if this will be read previous posts have been a little aggressive.
Your given little info but assuming that the stairs are on the outside of the tank, calculate you path as the circumference not the shell and stand off the stringers from the shell far enough to get the horizontal dimension for the angle required.
The design is still in your court I believe that to be a solution.
Re: Staircase
12/08/2014 1:31 AM
That approach could be successful. My earlier quickie calcs were based on the o.d. of the tank, but using the o.d. of the stairs could reduce the slope enough to be OSHA-acceptable. (Or acceptable to local standards).
Re: Staircase
12/08/2014 5:15 AM
Quote "how i complete staircase for this tank within 270deg angle with 1 platform."
Get some steel and a welder. Start 17M away in an easterly direction and put the first platform at 7.5M high and build 2M towards tank. Make first staircase up to landing from 32M away and then make second staircase from landing to top of tank.
I am assuming you want to go to the top of the tank. If not, ignore my post.
Maybe you want to go around the outside of the tank for the first half then put the platform through the tank wall to join to the second half inside the tank. Or is it the other way round?
Seriously 'though;-
Once you have defined what you want you will be better placed to work it out for yourself. Get a piece of paper 15cm by 15cm and roll it into a tank shape, mark on it want you want and that might help you as well.
Jim
Hobbies - CNC - New Member
Re: Staircase
12/08/2014 11:15 AM
You have almost everything you need to make the calculations yourself. This a really good homework brain teaser. My answer is call the tank builder and ask them to install it. Give them the dimensions and listen to them laugh at the ridiculousness of the specifications. Try this instead:
Re: Staircase
12/09/2014 12:18 PM
Here is a scale model of the tank. LOL!! The dimensions do not make sense?
  1. 15m Circumference = 15.6 ft. diameter = 187" Dia.
  2. 15m height = 49 feet = 590".
  3. The staircase specifications are 3/4 the way around the tank = 270 deg.
  4. A typical step is approx. 8" in height and 12" in depth = 8" rise with a 12 " run.
  5. These are rough measurements and I'm rounding to make this easier.
  6. 590 / 8 = 73 steps.
  7. 187 * 3.1416 = 587".
  8. (587 / 4) = 146.75" * 3 = 440" on the circumference or 270 deg.
  9. Assume a 36" platform 1/2 way up the tank at 24'.
  10. 440" - 36" = 404" total length to install stairs.
  11. 404" / 73 = 5" for your stair tread next to the tank and 7.125" away from the tank.
Here is a drawing of your stairs.
This design becomes more of a ladder step rather than a standard sized step.
Good Answers: 70
Re: Staircase
12/09/2014 10:50 PM
I love nothing more than doing some student's home work assignment.
So, who really benefits from this interaction?
I don't think it's the student
Re: Staircase
12/10/2014 9:46 AM
I hope he doesn't use my numbers because my rounding puts the top step floating a few inches above the top of the tank being suspended by a Skyhook designed and built by LynDor® Industries (pictured below). I also like to throw a few other numbers in too just to mess with them. I figured that if I'm given a theoretical problem, I will give a theoretical answer. In Theory, a student should do their own homework, I assume!
Re: Staircase
12/10/2014 10:09 AM
I mentioned the 'magic' number 17" in an earlier response, i.e. 1 tread and 1 riser added together, it's the average persons comfortable stride when ascending. Also...this value should remain constant through out the run, if it varies by as little as 1/4 inch it can introduce a trip hazard as your mind gauges the step on the first few, and if it changes, you will stumble. A framing square and a couple of clamps makes layout simple, once you've calculated the 'rise' for the 'run'.
Re: Staircase
12/10/2014 11:03 AM
The OSHA "magic number" is 17.5 rather than 17. It is given as a permitted formula, but not mandated.
Re: Staircase
12/10/2014 11:19 AM
When I was a building Contractor in California, one of my specialties was custom decks with built in tables, benches, roof coverings and of course stairs. Yes the magic number is 17.5". however, I was building these custom decks for the client that owned the home and would design for their height and weight at the time of installation. I found that when you have a longer "run" on an exterior deck, especially around a pool, the larger step provides a much more comfortable position to stand on when your feet are bare or wet. You want to be able to support the entire foot, not just the "ball".
Re: Staircase
12/10/2014 11:56 AM
In my town there is some dumb contractor that builds 7.5 x 7.5 (or even smaller) Munchkin stairs. There may be some merit to oddball custom sizes, but if the building is sold, the stairs may be all but unusable for anyone else.
"Tread" alone means the net run, or horizontal pitch. "Tread width" includes overlap (or nosing) of adjacent treads. As you mention, larger tread widths are especially helpful in wet conditions.
Re: Staircase
12/10/2014 2:20 PM
I haven't researched history of it, but I'll bet the 17" was increased to 17.5" sometime in the last 50 years due to the increase in average height. (I joined Local 1243 as a journeyman millwright in 1969 and if I recall correctly at that time 17" was recommended.)
Re: Staircase
12/15/2014 1:46 PM
Try this Android App.
https://play.google.com/store/apps/details?id=appinventor.ai_davivalcesp.StairCalculatorCAD
Good Answers: 137
Re: Staircase
12/16/2014 6:26 AM
I don't know why we bother. The OP has vanished without trace, not unusually.
Re: Staircase
12/16/2014 9:12 AM
That's true in so many cases where they are looking for someone to do their homework. I enjoy finding solutions to unique challenges, that's why I continue. Now only if the OP had the same diligence, they may have done their own homework.
Good Answers: 137
Re: Staircase
12/16/2014 9:38 AM
That's right. I still think it's more likely to be 15m diameter than 15m circumference, but I don't suppose we'll ever know
Register to Reply 41 comments
3E reading (1); Anonymous Poster (2); Codemaster (6); dj95401 (2); geraldpaxton (3); JIMRAT (1); lyn (2); Original_Macgyver (6); passingtongreen (1); phoenix911 (6); sanweld (2); Tornado (6); Whitephone (3)
