Previous in Forum: Expanding, or Contracting?   Next in Forum: "Practical Solar?"
15 comments
Does Anyone Know What a Cold Press Is?
12/10/2014 3:53 PM
A friend of mine had the contacts fall off the terminals on the heated rear windscreen.
She showed me the connecting wires: they were simply thick sections of stranded wire (about AWG16 I'd guess) approx. 3 inches long, with a spade crimped to one end and the other end soldered to a contact about 1 cm², and, silver on the side which was supposed to be connected to the windscreen.
The garage she originally took it to, said that if she knew someone with a cold press they could re-attach them. None of the places she tried had any ideas, so, in the end she just had the whole windscreen replaced.
I've Googled cold press with no luck. I did find a few people who had re-connected the contacts with PCB repair fluid/pen or other conductive glue and then formed a strong mechanical joint over the whole area.
Of course there may be a completely different name for this thing in the US, but, again I had no luck searching.
6
Re: Does anyone know what a cold press is?
12/10/2014 4:00 PM
Forget "cold press".
Frost Fighter Defroster Repair and Replacement Kits
Look at defogger repair kits.
They use chemical reactions of conductive adhesives to make a "cold' repair.
Hobbies - CNC - New Member
12/10/2014 4:16 PM
Lyn,
Jeez, slow down, give someone else a shot at grabbing the brass ring.
Just Kidding.
PERFECT answer!!!
I have also used conductive epoxy in these cases when I cannot find the product you showed.
Use a bit of masking tape to keep the wires in place while the adhesive cures. You may also want to mask around the attachment area to keep the area a bit cleaner while you apply the tabs to the window.
12/10/2014 5:17 PM
I took the day off. I have a cold and my office-mates made me leave early yesterday.
My new phart smone was delivered this morning and got it going so now I'm just hangin'.
Besides, I worked with conductive adhesives in the 70's. Mostly silver filled.
That was during the time when the Hunt brothers tried to buy up all the silver in the world.
12/10/2014 6:08 PM
So you have a pressing cold, I see. Lyn, I hope you feel better. Since I joined this forum I have seen your posts in so many of these topics and you'd knowledge is wide and varied. And correct on pretty much every topic you reply to. I appreciate and value your input mostly because it is based in reality and is what I would call good common sense.
12/10/2014 6:55 PM
Thanks, on both counts. I'm on here a lot. Too much, some say.
I, like you, learned by doing. And listening! And by accumulating almost 50 years worth of mistakes experience in different fields.
I am a legend in my own mind.
Good Answers: 225
12/11/2014 1:37 AM
You think you have it bad. Aussies don't even see the CR4 daily until around 7 hours after you lot
It's all old news by then.
12/11/2014 9:08 AM
It takes that long for the Internet to get there, are you still on dial-up at 3200 baud?
I knew Australia was far away but that's crazy. Maybe if you were able to get the water to reverse it rotation while draining, the internet will speed up, just a theory? Something about the magnetic flux in your hemisphere?
Good Answers: 21
12/11/2014 5:05 AM
Glad you had this one covered! I thought' cold press' must have to do with processing grapes or olives..........
12/11/2014 5:45 AM
Thanks Lyn, now I know what to look for plenty of sources in the UK too.
12/10/2014 4:21 PM
This is a cold press.
When life gives you LEMONS, make Lemonade!!
Did you see that you can spell MELONS with LEMONS??
Good Answers: 94
Re: Does Anyone Know What a Cold Press Is?
12/11/2014 5:25 AM
Cold press in the semiconductor industry is the joining of parts by pressing a hard metal component into a softer one. In our products, the old way of doing a final seal under vacuum was to push a nickel alloy steel part into a bed of indium/tin or indium/bismuth alloy which cold flowed into grooves in the steel to create the seal.
Maybe this relates in some way to how they make the screen contacts?
12/11/2014 5:49 AM
Thanks Nigh, This looks like the sort of thing that "they" were referring to, but, I can't imagine that it would be appropriate for the task in hand.
12/11/2014 8:56 AM
I thought "cold press" was an odd term too, till I remembered that you guys drive "lorries".
12/11/2014 9:52 AM
I would not use a cold press to try to re-attach a broken window defroster tab. I'm picturing the rear window in a billion pieces on your rear seat and trunk! it may work in the initial manufacturing of the window however I would never put that kind of stress on automotive glass.
Good Luck
12/11/2014 10:42 AM
A cold press is the opposite of a hot press.
Why not just use the crimping pliers/wire strippers to remount some new terminals?
Register to Reply 15 comments
Hilton (1); James Stewart (1); lyn (4); Nigh (1); Original_Macgyver (5); Randall (2); spades (1)
