Previous in Forum: Does Torque Drop?   Next in Forum: Bolts
Flue Gas Velocity in the Furnace
01/14/2015 5:39 AM
how should i calculate the flue gas velocity in the furnace. which parameters should i consider for this calculation of a coal fired boiler? I am trying to calculate the heat transfer coefficient for different surfaces of a PC fired boiler.
Thanks in advance.
Pathfinder Tags: flue gas velocity
Re: Flue Gas Velocity in the Furnace
01/14/2015 12:36 PM
You don't need to calculate the velocity. Just measure it.
Good moaning!
01/14/2015 3:41 PM
its!" Economizers and Air Heaters
If the paper is not readable, contact:
www.me.gatech... George W. Woodruff School of Mechanical Engineering
They may want you to pay for it.
01/14/2015 6:41 PM
Buy a pitot tube and float ball meter for velocity measurement
"When I thought I exceeded to be wise but wisdom was far from me" -King Solomon
Good Answers: 109
01/14/2015 8:15 PM
If you know the mass flow and the furnace flow area . . .
01/14/2015 10:04 PM
thanks all..
Crabtree (1); IdeaSmith (1); Kulas (1); lyn (1); Md. Muhiminul Bari (1)
