Previous in Forum: ASME Section IX   Next in Forum: Superhydrophobic Metal and Heat Transfer
Superheater Tube Arrangement in Steam Boiler
01/21/2015 6:35 AM
how can i select the number of tubes of a superheater through which the steam flows in steam boiler. As I know the total steam flow of the boiler, to calculate the heat transfer coefficient of the steam i need to find the steam flow per tube? I am trying to use the equation given below,
h= 2.44 * w^.8 * C/d^1.8
here w= the steam flow rate per tube= total mass flowrate / no of stream tube
Now how to select this no of stream tubes for superheater? as far I know this is not equal to the total amount of tubes.
P.s. the steam flow rate is 1650 tph.
can anybody help me in this regard? Thanks in advance
Pathfinder Tags: superheater design
Re: Superheater Tube Arrangement in Steam Boiler
01/21/2015 8:23 AM
If this is a new boiler design then it does seem implausible that the organisation's design standards contain insufficient information on how to design a superheater arrangement! Superheating has been going on for many decades up to now.
  • The number of tubes is constrained in the upper limit by the diameter of the flues down which any superheater element needs to be mounted and the number of flues.
  • There should be a superheater header manifold at each end of the superheater elemments, each of which should have the same number of holes, and this may determine the number of superheater elements to be fitted. It is a simple task to count the number of holes in each header manifold to determine that number.
  • The inner diameter of the superheater elements has to be sufficient to allow steam to pass at a typical upper velocity of 10m/s: much smaller than that and the elements may be too big; much bigger than that and the elements are too small.
  • The difference between the inner diameter and the outer diameter gives the wall thickness, which needs to be sufficient to withstand the pressure of the steam at the highest temperature to which the elements are to be exposed allowing for any scaling-up that might occur over time, which is a function of the strength of the material selected, the feedwater treatment regime and the blowdown regime.
  • The maximum number of superheater elements is constrained by the materials of construction and the pitch between the tube holes in the superheater headers allowing for several refits during the life of the boiler; if the boiler is intending to last beyond a single insurance assessment period then this must be taken into account in the design of the superheater headers.
  • The superheater header design may be constrained by the boiler structure.
The rest can be seen at the original poster's offices and the original poster's plant.
<unsubscribes>
01/21/2015 11:35 AM
The design engineer who is doing the work should know how to figure this out. Ask her.
Or, ask the fabricator what size tube she prefers.
Good Answers: 19
01/21/2015 10:16 PM
She.
Good Answers: 16
01/21/2015 11:47 PM
This sounds a lot like a home work assignment. I hope it is a home work assignment! If you are designing this for real you should know this sort of stuff. If it is a real design please make sure that the internals are easy to clean. That would make such a difference to down time. Also let me know where and when this boiler gets commissioned so that I know I am at a safe distance.
Make it so.
01/21/2015 11:55 PM
You're safe, I think.
Trainee Design Engineer. KDS Heavy Engineering Ltd. Bangladesh
Good Answers: 32
01/28/2015 2:42 PM
This concept of Designing a Boiler by internet thread is really, really scary.
Spinco
Register to Reply 6 comments
BlueAussieBoy (1); lyn (2); PWSlack (1); Spinco (1); Wrench twirler (1)
