we found in one of our project NC proximity limit switch used for ESD valves open /close indication . When tagret come against the respective sensor voltage increases 4 to 7 volt as well as the digital contact become 1- 0 respectivley . so fail safe action could not be achived if sensor wire break condition . To achive fail safe aspect vendor used opposite switch i mean OPEN switch used for close indication when valve closed . same for reverse also . So physcially when valve is open the valve cam against the close sensor . in this case . valve not closed 100% dcs shows close indication . I just want to discus about this . we are having dip switch adjustment provision in barrier and its dual barrier .
