Hello,
I have a 1/4th hp 2 pole 115 volt induction motor.
run winding is between 3.3 and 3.6 ohms.
A 10uF capacitor is in series with a 13.3 ohm coil. (it wouldn't supprise me if its exactly twice the turns and half the cross section area for four times the resistance)
No load voltage is 254 volts across the capacitor, and 211 volts across the coil, .98 amps through the capacitor at no load. under as much load as my fingers can burn up.. the amps drop to .88 through the capacitor and the volts drop to 190 across the coil.
What i'm wondering is, can i drive this from a standard 3 phase vfd. using a small 100 watt auto transformer to double the volts for the second winding..
Instead of a psuedo 90 degree phase relationship I'd have 120 fixed, so its a bit of a de-rating.. however the volts won't drop under load so I expect to get more torque out of it. overheating isn't an issue right now.
Or should I just build a Scott T transformer.. which would be very easy to do.
